Question about Garden
What is the correct gas/oil mixture for a Poulin chain saw model #2800?
    Sergeant:
  • 281 Answers
Hi there,http://lawnandgarden.manualsonline.com/support/poulan/chainsaw/user-or-service-manual-1285532
If this is an older saw here is a site that said the oil mix is on the tag.I couldn't find your exact model.
    I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
 Thank you for choosing FixYa.com.
Posted on May 23, 2011
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My saw simply will not pump chain oil. Iv'e run it with the bar and chain off and the pump works.Put it back together and nothing. Before reinstalling the bar I blew the saw clean. I had a Sears Poulin a...
Check that the bar oil ports are clean; there should be a small hole or slot on each side of the bar and these can become pluged with sawdust. Also clean the groove in the bar with a small screwdriver or bar cleaning tool every 8 hrs of operation.
If this does not fix the problem check the oil sump screen in the oil tank(usually on the end of a rubber hose); if no screen in tank: remove oil pump and clean(screen is sometimes in oil pump assembly).
Oct 06, 2010 | Poulan Pro Chain Saw 46cc 20"
DONT HAVE PROBLEM JUST NEED TO KNOW MIXTURE OF GAS/OIL FOR POULIN PRO 20 INCH
The correct mix is 40:1. That is 3.2 oz 2 cycle engine oil to 1 gallon regular unleaded gas 87 octane. Use ethanol free gas if you can. Ethanol will damage your fuel lines in time.
Oct 03, 2010 | Poulan Garden
Every chain saw uses as fuel a mixture of oil and gasoline. What is the correct mixture for a textron gasoline powered saw?
25:1 to 32:1
Start at 25:1. If it smokes too much or fouls a plug, go to 32:1 using a good grade 2-cycle oil.
Sep 27, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the gas/oil mixture for poulan wild thing chain saw? Thank You Roger
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
Dec 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Apr 26, 2009 | Remington 16" Electric Chain Saw
Gas to oil ratio for chainsaw
You will want to mix at a ratio of 40:1. that is 40 parts gas to 1 part 2-cycle oil.
Mar 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
