Question about Clarion M235-RET CD Player
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than the old. I have only two speakers. Can you give me the color code for the wiring ?
  • 6,674 Answers
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
Posted on May 22, 2011
I just bought a used pontoon boat with a Clarion Marine M235 radio/cd player. The previous owner said there is a cd stuck in the player and won't eject or play. The display says "no cd" but I...
you have to open the unit cover to remove the CD, its probably tried to eject it and its past the point that shows one in the slot which is causing the player to say NO CD , once opened, use great care in moving anything, and keep track of where everything goes,
Jul 04, 2011 | Audio Players & Recorders
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
How to remove a Clarion AB213R radio-Cassette ?
It depends on the type of Clarion Radio.
There are 2 types of Clarion Keys depending on the size of the removal slots in your radio  ...the older , larger version or the later slim version.
See the difference here
http://www.incaripod.com/Brand/Radio_Removal_Tools
Available on Ebay , local car radio store etc
Jan 22, 2010 | Clarion Car Audio & Video
Clarion marine radio m275 i need a instruction
you can get the instruction book in the following websites.
www.bizrate.com/marineelectronics/clarion-m275-marine.../compareprices.html
www.amazon.com/Clarion-M275-Marine.../B000PHFVKW
www.crutchfield.com/ISEO...020M275/Clarion-M275.html
Jul 26, 2009 | Audio Players & Recorders
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Clarion M235-RET CD Player
CD PLAYER IN boat says ACCS and does not work, i have power and i checked the fuse's all working but the screen reads ACCS and i cannot remember how i fixed it the first time this went wrong,
OK, so I spoke with a Claion reseller and they were very nice and helpful. ACCS mode is accesory mode. This can happen if the brown wire in the back touches ground or the case on the radio. If it is not, tap the brown wire on the yellow(hot) wire and that takes it out of that mode. I tried it and it worked. Good luck! And thanks Clarion for your support on my 3 year old radio!
Apr 10, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Installation manual clarion m455a
Here is the product page:
http://www.clarion.com/us/en/products/2006/marine/source_units/M455A/us-en-product-pf_1151544055054.html
And here is the manual:
http://www.clarion.com/us/en/MungoBlobs/797/154/M455A_ENG.PDF
In page 33 you'll find the wiring chart.
Dec 01, 2008 | Clarion M455a Marine Cd Receiver
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
Clarion radio wiring diagram
Usually the yellow is for ignition switched-red is permanent +...;)
Aug 03, 2008 | Clarion ARX6670Z Cassette Player
Clarion M235
It needs a new CD mech. Hopefully you can exchange it from the shop you got it from.
Sep 19, 2007 | Clarion M235-RET CD Player
Clarion M235-RET CD Player Logo
291 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
