Question about Maytag MMV4205 Microwave Oven
The turntable will not work. Help!!!! It is model number mmv4205bas
    President:
  • 2,080 Answers
Fisrt check that there are no crumbs or other obstructions on the floor of the oven that would prevent the turntable assembly from rotating properly. Also try removing the plate and lifting up / checking the drive assembly inside the oven cavity to make sure that the turntable drive mechanism has not become disengaged from the motor shaft underneath.
If your problem is not something inside the oven cavity itself, then it may be the result of a simple loose wire to the turntable motor, or it may be a completely burned out motor altogether. Unfortunately the only way to determine the exact source of the problem for sure is to disassemble the unit and troubleshoot the components and connections inside.
A microwave contains a number of very hazardous components such as the main capacitor which can deliver lethal shocks even after the unit has been unplugged. Extreme care should be taken in the disassembly and maintenance of any microwave oven and should be left to a trained technician whenever possible.
Here is a link to the parts diagrams and price lists for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174676
The turntable drive motor is listed as part number 27 on the diagrams. Here is a link to the part details including price for that item if required:
http://www.appliancepartspros.com/part_details.aspx?part_id=4215435
Hope that was helpful. Good luck and take care.
Posted on May 22, 2011
Part number for turntable glass tray
Only two Sizes of Turntable Glass Tray , Each manufactuer has his own number, but any Microwave repairer / supplier can help you. Try Yellow pages.
Mar 11, 2015 | Microwave Ovens
Turntable stopped working (yes, I pressed the turntable on/off button)
It all depends on your model number of course, but if JUST the turntable is failing, it may just be a defective turntable motor or coupler.
If your internal cooling fan and/or inside / cavity light is defective, too, it may be the internal fan motor, a door switch, or a relay on the control board.
We repair those and can offer more free advice with the full model number and a little bit more detail about what's working, what's not, and when.
You can find handy exploded views and order parts by model number here.
Nov 27, 2012 | GE JVM1850 1000 Watts Microwave Oven
How to replace turntable on maytag microwave mmv4250bas
Is that MMV4205BAS?
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
First unplug the oven. Then you have to remove the bottom panel and then you'll see the turntable motor.
Unplug the wires from it, then remove the mounting screws.
Reassembly is the reverse, but be sure to put the coupler in and guide the motor into it, making sure the coupler properly engages the motor shaft before you tighten the screws.
Dec 20, 2011 | Microwave Ovens
How can I view installation Instructions on a Maytag over the range microwave MMV4205BA
It depends on your full model number:
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Dec 17, 2010 | Maytag Microwave Ovens
I need to replace just the door handle on a Maytag Microwave (Model No. MMV4205BAS). All I've seen online for parts is a complete new door for anywhere from $220 to $300. Surely there is a cheaper...
The handles run about $25-35 here.
Here are the part numbers & descriptions:
W10279351 Black handle
W10279353 White handle
W10279355 Bisque handle
Sep 07, 2010 | Maytag MMV4205 Microwave Oven
MMV4205BAS no power. Was not using it.
Try checking the fuses under the button panel.
Jun 08, 2010 | Maytag MMV4205 Microwave Oven
I have a 1993 1000 wt microwave the turntable was not work are there still parts these are the numbers I can find on the door 565383 10/01 ( model) HG34314163 ( serial)
You can find helpful exploded view diagrams and order parts by entering your full model number here.
NOTE: Enter your model number like this: 56-5383-10-01
The typical turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
Sep 26, 2009 | Tappan TMS062E1 Microwave Oven
How do I mount a maytag mmv4205bas microwave? I bought a floormodel and they did not have the template.
Go to this website:
http://www.servicematters.com/maytag_library/html/index.html
-Once there click the link at the top "Literature by Model"
-Now enter your model number "MMV4205BAS" and hit enter or "go"
-On the page click your model number
-Click on the first row or the row containing the Document Type of Service Manual
-On page 51 of that PDF you will see the installation instructions for your microwave.
Apr 09, 2009 | Maytag MMV4205 Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Glass turnable replacement
This answer assumes your model is MW8168B - if not, please reply back with your correct model number!
The original part number was shown as M0S0885 (or MOS0885) but it is listed as "no longer available".
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. I've attached a photo.
One last option would be a Nordicware or Rubbermaid or similar wind-up carousel. Wal-Mart had them when I checked a few months ago, and you can probably still find them on Google's Froogle site at http://froogle.google.com by searching for the key words: wind-up turntable.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 21, 2008 | Emerson MW8168B Microwave Oven
Maytag MMV4205 Microwave Oven Logo
328 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
