Question about LG Washing Machines
New LG Waveforce washer. Door lock doesn't want
SOURCE: door lock
my kenmore elite he4t did the same thing last month. I unplugged it for about 5 minutes and it re set itself and worked great until today...any suggestions???
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: I HAVE A FAULT CODE F 11 AND DL F
try hitting pause cancel twice to clear the code and shut the door hard then try again and advise
Posted on Mar 02, 2008
SOURCE: door lock
I posted a complaint on December 31st about the error "DL". After leaving the wash machine sit for awhile out of frustration my husband & I went to look at it one more time. He went to hit normal as the wash cycle & we got the same error message so he proceded to cancel the error & he hit the heavy duty button & then start & then it was fine & it started to wash. It was a simple solution that seemed to have worked but it would have been nice to have some troubleshooting help from the company that sold me the appliance but seeing that I was out of warranty by 2 days they would not help me. Try this & see if this helps.
Posted on Jan 08, 2008
I thought F DL meant Failure Door Lock. That is the way I was going to tackle it. Would doing that be a waste of time?
Posted on Feb 24, 2008
the dr
  • 447 Answers
SOURCE: dl/f
Ok the problem could lie in the door latch assembly itself, however i have had a few of these machines throw this code and the issue was the main computer. The only real way to test this issue is try replacing the latch first its much cheaper than the computer...if it still throws f dl than it will need a new CCU (main computer)
Posted on May 18, 2008
We have LG top load waveforce washer showing error code dL. At start there is a few seconds noise then error code appears. The washing cycle does not start. What is the problem and how do I fix it.
most likely a Door Lock error. means that the door lock is not working. fairly easy replacement if necessary. might check the lock first to make sure it has connector plugged into it. and that nothing is jammed inside of it. good repair videos at repairclinic.com and appliancepartspros.com or online at youtube.com
Oct 30, 2016 | LG Washing Machines
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Lg waveforce washer makes grinding squeeking noise drum hard to trun.
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
The tub bearing also appears to be part of the problem.
Aug 22, 2014 | LG WT5170V 4.7 cu ft High Efficiency Top...
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
DE code, machine will not run. door working properly
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Aug 06, 2011 | LG WM2042 Front Load Washer
Trying to start washer...express wash....code dl f came up.. what is that? how can I fix it.
I'm presuming that 'dl' stands for 'door lock' fault.
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 05, 2011 | Kenmore Elite 45986 Front Load Washer
I have a fault code of "F DL "
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Jul 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The DL error just came on. Is there something specific we need to do to fix this? It has been working fine, but then all the sudden the error started. Upon initial machine start, it works fine, but then if...
Presumably it is still under guarantee/warantee? You should contact the washer's service department before doing anything else as 'DL' does stand for Door Lock (error).
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor needing an engineer's attention ;-0(
John C
Jul 16, 2011 | LG WM2277H Front Load Washer
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
Getting a code of dl then f on display
'dl +F' stands for Door Lock Fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
John C
Apr 21, 2011 | Kenmore HE3T Washer
Washing Machines Logo
407 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
