Question about Alpine CDA-9847 CD Player
Screen says searching when iPod connected to Alpine CDA-9847
Last week my iPod worked fine with the deck (Alpine CDA-9847). Now when I connect the iPod to the radio the radio screen says searching and the Apline screen doesn't display on the iPod. The only thing I have done to troubleshoot is to reset the radio… that didn't work
  • 1 more comment
  • kenneth m Sep 11, 2008
    I have the same problem. However, before the problem arose, i put in a busted phone charger causing a spark. I checked all my fuses and none were tripped. I am wondering if they are related??
  • Anonymous Apr 03, 2009
    I have the same problem - it worked fine one day, then next it sisn't. I don't believe the problem is because I have my iPod on shuffle beacuse this is how I used to set it before (when it did work.) Very frustrating!
  • Lococo May 20, 2009
    The ipod was working fine with the deck...I changed to tuner and when I swiched back to ipod i said "searching"and still with the same message. I laready reset teh deck but it did work.
Check your ipod to see if it is shuffle mode. Alpine doesn't document this but they have a bug that causes the problem that you describe. If the ipod is in shuffle mode the Alpine gets confused.
Posted on Sep 29, 2008
Where do you plug mp3 or ipod connections
Unfortunately your deck does not have any ports for ipod or mp3 players. If you would like to connect such items you need to upgrade. Here is the link that has your deck specifications
http://www.crutchfield.com/p_500CDE9843/Alpine-CDE-9843.html?search=Alpine+CDE9843&tp=5684&tab=features_and_specs
I am not a fan of CDE line, you are better off with CDA line.
Sep 19, 2010 | Alpine CDE-9843 CD Player
Radio memory/presets
you need to have the yellow wire going to a constant power source for the radio to retain memory when the key is off.
Mar 12, 2010 | Alpine CDA-9847 CD Player
Model CDA9847, how to set the clock?
Link to a PDF Owners Manual for the Alpine CDA-9847...
http://vault.alpine-usa.com/products/documents/OM_CDA-9847.PDF
"Setting Time" is found on Page 7.
Jan 27, 2010 | Alpine CDA-9847 CD Player
KCA- 420i and an alpine 9854r Can't change the volume for Ipod
There is a small switch on the unit's housing, switch it to "Norm" position.
May 08, 2009 | Alpine CDA-9847 CD Player
Connect to sirius
you need a tuner for your alpine that is specifically for the unit, the portable will not interface with your indash controller
Mar 20, 2009 | Alpine CDA-9847 CD Player
Alpine 9884 and ipod hook up
No. This unit is designed to choose songs through the deck itself
Oct 10, 2008 | Alpine CDA-9884 Car CD/ MP3 Player
Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Dec 30, 2007 | Alpine CDA-9851 CD Player
CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Aug 12, 2007 | Alpine CDA-9885 CD Player
IPod will not work.
restoring factory settings won't revert the player back to previous ipod software. Check with the alpine website product support and see which ipod software versions are compatible with the car deck you installed. I would think the latest version would be supported. then go to the apple website and download the most recent version of itunes that alpine says is compatible. connect your pod and open itunes. upgrade the pod to that itunes version and try it again with the car deck.
Jul 30, 2007 | Alpine CDA-9883 CD Player
Alpine CDA-9847 CD Player Logo
1,170 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
