Question about Vacuums
Leg messager 'Leg Beautician' SL-c11 stopped working. Any instructions how to fix or open it
Im trying to wind the bobbin and the machine stops and an 888 message appears. How do I fix this problem?
It could mean your winding too tightly and must loosen the tension. Your operators manual will tell you what to set it at for this purpose.
Sep 09, 2014 | SewShop.com Singer Model 7466 Instruction...
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 | Vacuums
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
My Beaumark popcorn maker isn't working! I have the type that is a large domed electric pan, with a metal 'stick' that goes around to move the kernels (presumably to stop them from sticking?)....
your problem is in the instructions.. you need to make it a little hot, means run it on empty for a few min. stop the machine, and add 2 tablespoosn of veg. oil your fav. oil, not olive. add enough pop corn to fill the inner circle surface of the bottem plate, then run it again until the bowl is full.. maybe 5 min. You should have perfect bowl full of pop corn.
enjoy :-)
Sep 15, 2011 | Vacuums
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
I need a download for the instructions that came with a Heath/Zenith SL-4142-B motion-sensing porch light.
I was looking for the exact same thing today and found out it is the same as the SL-4152-B instructions:
http://heath-zenith.hcents.com/data/manuals/595-5578-09.pdf
Hope that helps. Enjoy.
Jan 02, 2011 | Vacuums
T Fal fry expert manual
My friend give a Fry expert but haven't manual. I don't know how long to fry chicken leg or fried. Could you provide to me?
Oct 25, 2010 | Vacuums
Rainbow vac ESeries brush stopped spinning
If you have tried to press the red button on the top of power nozzle and it is still not working, try opening the bottom to see about loose wire, check receptacle that plugs into rainbow, if neither of those are the problem than it may be you need a new motor. Should not really be an arm and a leg.
Dec 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
155 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
