I need to find the WPA button so I can set up wireless printer
    Guru:
  • 868 Answers
Hi sam,
I see that you are looking for your WPA security info.
You will need to get in your Router then click on the wireless button or TAB look for security that should give you info about our WPA.
I hope this helps.
Have a nice day,
mvincentc
Posted on May 22, 2011
I cannot find information I need to connect to my wireless hp printer I need wpa key or wep passphrase
When you installed your wireless router, you should have configured its wireless interface:
* set an SSID -- the "name" of your network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password or pass-phrase for your network
Enter the SSID/password on your HP printer, to connect it to your router.
Apr 22, 2011 | HP Computers & Internet
Got a new router and now can't use my canon mp620 wirelessly.
IT sounds like to need to reset up your printer for the new router:
Gather the following information from your router: • Access Point Name/Network Name: Also referred to as SSID. A name to identify the specific access point. • Network Key: Also referred to as encryption key, WEP key or WPA/WPA2 passphrase, Pre-Shared key if you used one
use the buttons of the front of the printer near your display to select Settings, then press the OK button
Select Device settings, then press the OK button
Select LAN settings, then press the OK button. Select Wireless LAN settings and update with the new information you collected earlier.
Hope this helps
Apr 20, 2011 | Canon PIXMA MP620 All-In-One InkJet...
On my HP photosmart how do I find my WPA Passphrase. I have a Nexxt solutions wireless-N broadband router and Cable & Wireless TP Link, routers. I live in Panama, Central America
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers can communicatewith your wireless router.
Apr 15, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have an acer computer with and hp photosmart printer connected to a belkin router what is the wpa passphrase to link them
on the front panel of the printer press the tool button and look for wireless settings and press ok. under wireless settings look for wireless setup wizard. it will ask for you wep/wpa. it's the same as your wpa when connecting to a wireless router or wifi.
Mar 23, 2011 | HP Photosmart Premium C309A All-In-One...
I have a D-link model DIR-628 and I want to use it for direct my wireless printer, the printer setup ask me for the WAP passphrase to end configuration but I don"t have it. How can I get it?
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the wireless printer, or laptops or computers needs to be configured withthese router's wireless settings. Then the wireless printer, laptops and desktop computers cancommunicate with your wireless router.
Mar 11, 2011 | D-Link DIR-628 Wireless Router
On my printer a hp c7280 all in one it ask me for
This is the passphrase for your wireless network. When connecting to the printer wirelessly, it needs to authenticate. The WPA phrase is what you typed in to access the wireless network with your computer if you did so.
The wireless router is a gate. The printer needs to get through the gate so it needs the password otherwise it can't get access. If you don't have this info readily available, please check your routers documentation as to how to retrieve it.
Hope this helps. Have a great day and don't forget to rate!
Feb 26, 2010 | HP Office Equipment & Supplies
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Printer asks for wpa passphrase I enter the correct passphrase but the printer says it is wrong
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 12, 2010 | Linksys Wireless-G Broadband Router
Security passphrase for wireless printer
The WPA security passphrase is stored in the wireless router's wireless encryption settings. You need to open the browser and enter the router's URL comfiguration IP address, login and go to the wireless settings.
Dec 14, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Just installing for wireless but does not pick up network ,wireless light is on. Thanks
Try this :
Press the setup button on the printer;
Goto network setup
Run the wireless setup wizard
It will ask for the WEP or WPA key (Wireless security key)
If you don't have it contact the router company other can check from the EWS page ; put the default gateway(ip address ) in the address bar fo IE and check for the wireless settings; Even if you dont get it check the Below given Link for The network diagnostic utility ; Download it on your desktop and run it ; it will give the WEP/WPA key
Network Diagnostic Utility:
ftp://ftp.hp.com/pub/printers/ndu/
Click on HPHNDU..
Save it to your desktop
Check the WEP/WPA key
Put it in the printer
Select done it will get connected to the network
for further help can check the link given below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01491627&cc=us&lc=en&dlc=en&product=3560280
Oct 25, 2009 | HP Photosmart C6380 All-In-One InkJet...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
