Question about Sportsstuff Big Mable Water Towable Boat Tow Tube
Nose of big mable keeps going underwater when towed tipping the towable into the water
We have a speedzone racing two seater water towing tub that keeps losing air....
Take it out the cover and pump it up. Then use a sponge and soapy water and check for leaks.Mark with a pen.
Get your Storm Sure from twister.com.au and use on hole...job done!
Jul 19, 2011 | 3M SportsStuff Speedzone 3 Inflatable...
Is the lancer towable behind moterhome
No vehicle is really towable with all four wheels on the surface. It is best to have a front wheel dolly trailer that the front wheels set on strapped down to tow by. The axles are freely moving if the tires are all on the surface creating a harsh wear to the transmission. The transmission is a hydralic pump as you may know & if the axles are moving for a long distance some parts inside the transmission will be fluxuating as you travel. Many vehicle end up at a transmission shop where I am at with some sort of drivability problem since they have been towed for a long distance. Usually inside your owns manual they will have a section on towing. I would read that section if you have the manual
Jun 19, 2010 | 2006 Mitsubishi Lancer
Can I tow a 2003 Suzuki LX7 with an automatic transmission?
Only the 4WD version is 'flat towable' - if yours is the front wheel drive version you will need a dolly as special equipment to prevent damage occuring to the transmission. Towing Auto vehicles is not really advisable in my opinion and unless it is specifically stated in the specification of the manufacturers handbook it is best avoided.
However you may want to check out this link which provides a list of towable pickups and SUVs that is updated each year. You can also find their list of towable vehicles from previous years there as well. These are vehicles that are factory approved by their manufacturers for towing behind a motorhome. Some vehicles such as the XL-7 require special procedures which must be followed, including speed and distance limitations.
For example, the 4WD version of the XL-7 requires special care to be taken every 200 miles in order to avoid the potential of transmission damage.
See link for more info
Hope this helps. Thanks for using FixYa.
Apr 23, 2010 | 2003 Suzuki XL-7
Is a 1990 Chev Corsica towable behind a motorhome?
it can, but I would talk to a trailer hitch shop that installs towing kits. some of these will have a pump to circulate trans fluid to keep the trans lubricated. They could best advise you.
Sep 26, 2009 | 1990 Chevrolet Corsica
Have a leak in my tube in my super mable inflatable raft
Use Sevylor Seam Seal...liquid gold it will fix it try www.twister.com.au they sell it!
Jul 15, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
4x4 Automatic, manual transfer case. Need to know maximum flat towable speed.
I would think if transfer and trans. are in neutral it would not matter how fast you go with in reason.
May 09, 2009 | 1993 Chevrolet S-10 Blazer
Sportsstuff Big Mable Water Towable Boat Tow Tube Logo
Top Sportsstuff Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Sportsstuff Boating Expert? Answer questions, earn points and help others
