Question about Westinghouse Refrigerators
We bought a Westinghouse fridge on Saturday we hooked up the water as per instructions the water flows to the conection on the fridge but nothing comes out of the water dispenser.
    Sergeant:
    Champion:
  • 257 Answers
Is it brand new if so keep pressing the lever, I have had it take minutes before the water arrives. There is a long stretch of coiled tubbing inside that the water has to pass through.
Posted on May 22, 2011
Hi i have a Westinghouse side by side fridge freezer WSE6970SA there is no water at the dispenser . how do you remove the front panel from the water dispenser to remove it ?
https://www.bing.com/videos/search?q=replacing+water+switch+on+westinghouse+fridge+door&qpvt=replacing+water+switch+on+estinghouse+fridge+door&FORM=VDRE
Apr 19, 2017 | Westinghouse Refrigerators
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
We bought a used but newer model White Westinghouse refrigerator; brought it home, plugged it in. We can hear the condenser motor running, but neither side is getting cold. There is an additional hose of...
Some fridges have an internal fan that sounds like the compressor. If the compressor is running and the fridge is any good the inside will quickly cool and the condenser will become warm. If the outside gets warm but the inside doesn't get cool it is possible the defrost heater is permanently switched on because of a fault.
If the compressor is running and nothing is happening the fridge has probably lost it's refrigerant gas. Moving fridges can upset them and it is unwise to switch on straight away - they really need to settle for at least 4 hours. Switching on too soon can damage a lubricant deprived compressor.
Oct 04, 2017 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
I own a side by side black-n-stainless fridge and I bought a kit for the water/ice despenser, installed it as per instructions but not getting any water in the ice maker or out of the water. The water is...
If its got a filter under the frig. just hook your water to the house water line. If not then put a filter in the cabnet next to your frig. Or in a handy place to get to. And you will have to hold your water lever for a long time till all the air gets out of the line. there is a extra long hose you must fill up in your frig side. It is used to keep cold water ready to drink.
hope this is helpfull
Aug 12, 2009 | Frigidaire FRS26R4A Side by Side...
WATER DISPENSER NOT WORKING
It might be that you have a restriction at the water supply line serving the fridge. Check it for good flow (have bucket and towels handy!) If supply line is good, then move onto the fridge to check the water inlet valve(s). as newer models have 2 or 3 inlet valves, a main water valve for the entire unit, and possibly one each for the ice maker and water dispenser past the main inlet valve (solinoid).
You can check these by simply shutting off the main supply to the fridge from the house water line 1st, and then removing each water line from the supply side of the fridge and seeing if you have water flow from the house to the valve side. If you do, then reconnect the lines to the fridge valves and see if you can get water flowing to the other side of the solinoid/valve when you have someone try to get a glass of water from the water dispenser, etc.
It is possible that there is an obstruction in the lines, by not very likely. Normally it is a failed water valve(s) (solinoid) that causes low flow or complete loss of flow, especially if you've changed the fridge water filter or replaced it with the "cap" which eliminates filtering of the water.
It is that you'll likely have to replace at least one, maybe more, of the fridge inlet water valves. If you have the time, try to zero in on the failed one by bypassing each, one at a time, until you get water flow. That way, you'll only have to purchase just the replacement valve needed to get things working again.
Jul 07, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker
Hi. Thanks for the question. the problem is . the brass fitting is missing . Or not connected .If missing . The hardware store will have this fitting . Thanks .The Appliance Doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
"Cyber" brand wireless rechargable mouse
Okay i got the same problem i did everything press the big blue botton and the one on the bottom of mouse and still nothing....
ITS THE BATTERYS!!!! the ones that come with it are shiet i put some tranisonic ones into and it worked instantly the moment i put "good" ones in the red light came on instantly
Aug 23, 2008 | Computers & Internet
Ice-maker problem
it will respond better if you fill it with scotch
Apr 16, 2017 | Refrigerators
Refrigerators Logo
57 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
