Question about BFG Technologies AGEIA PhysX 128MB GDDR3 PCI Physics Accelerator Card
Hi, for some reason, after Windows 7 has loaded the fan stops spinning on the Ageia PhysX card. The fan also makes a weird noise which it never used to do. Do u know what's wrong with it? It's weird 'cause if I was to stay in the bios before windows boots the fan doesn't stop spinning, it only stops after winodws 7 has fully loaded.
  • 11,800 Answers
In BIOS the fan always runs at full power, in Windows the speed is supposed to be automatically adjusted, depending on how heated the processor is. In your card it appears that the fan is dying, no longer capable of running at anything but the full speed. You will have to replace it - follow this
http://www.squidoo.com/video-card-fan-replacement
Posted on Jun 14, 2011
Physx driver
Ageis was bought out by Nvidia a long time ago and their drivers are intergrated with Nvidia drivers. There is no such thing as seperate drivers for them now.
Aug 23, 2014 | Video Game Consoles & Games
When i turn on my pc all seems well for about 5 secs then the heatsync fan and the tower fan stop moving and at that point my video card fan starts spinning 5 times faster what would cause this
Following are the reasons for overheating, just take care of these things::
1. Stop Overclocking your CPU
2. Make sure your Heat Sink is placed properly above the processor
3. Clean the Processor fan, Heat Sink and other peripherals
4. Use High Speed fans
5. Use CPU Heat Sink Paste in the processor
6. Make sure your dint restrict the speed of CPU fan.
7. Use Additional Cooling Units
If such problems occurs due to internal errors then i would suggest to perform a full computer scan with pc optimization tool like PCFresher for an instant fix.
Feb 18, 2013 | Compaq Presario CQ5110F (NP185AA ABA) PC...
I need ageia physx driver
Get onlineand got to www.google.com In the google search box type: "MSISupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.You can also try Driver Guide at:
http://www.driverguide.com
May 12, 2012 | Computers & Internet
I have fan noise on my new ecs elitegroup GeForce GTX 460, a simple tuch on the fan and noise immidiatly goes away? HELP !!!
Hi samohtpfeffe, i've been having the exact same problem. if fan making noise because you video card is over heating, or you fan is about to die, if the fan stops spinning and this will cause video card to overheat and damage and system lock up or crash, i recommend you replace video card fan as soon as possible, to solve this broblem.
Good Luck!
Dec 01, 2010 | EliteGroup Computers & Internet
Won't spin makes weird noise.
Could be the motor coupler, transmission, or motor. Will it agitate now?
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Need to download ageia physx driver ver 2,8.1 to run game everytime i try to launch the game it says install latest ageia physx drivers ver.2.8.1
if you are trying to run empire earth 3... just uninstall it... even with the driver... it is downright awful... with choppy video and action... very bad... but if you really need it go get the driver go here...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 27, 2009 | Dell C521 DimensionTM PC Desktop
Card started making loud clicking noise i have tried blowing dust out of it when i start my computer within a few minutes clicking starts again
Hi, couple main reasons to get loud clicking in a computer. First is the hard drive, so if you can turn the system off and disconnect the power and the information cable from the hard drive, yes your computer will not boot all the way back into windows but that is ok since you just want it running for awhile to see if the clicking stops. Next thing would definitely be the fans, any fan in the system, the blade part of the fans can get loose sometimes and start to hit the sides as it spins around, you need to be sure about which part it is that is causing it, it can come from the power supply fan, the case fan, the video card fan, the cpu fan, and you might have more than one case fan, test by disconnecting one at a time just make sure to disconnect the device too so you do not over heat anything. Once you identify which fan just replace it, if its something like power supply or video card, unfortunately you might want to look into either warrantying the part or buying a new one.
Nov 01, 2009 | PNY GeForce 9800 GT, PCI Express Video...
My fan makes so much noise especially when i play video.Can someone help
The problem with fans is there really isn't much you can do with them. Normally they begin to make noise as the bearing assembly begins to wear, or it might just need to be cleaned. In either case you need to crack open the case on your laptop, then you can inspect the fan. You can try cleaning it at that point, but usually its easier just to replace it. The reason why it makes more noise when you play videos is because video media requires more system resources to run, which also generates more heat. So, while you have your laptop open you may want to check your video card (which should also have a fan) and make sure that its clean. A dirty video card will **** out a lot earlier than it should.
Jul 25, 2009 | Acer Aspire One AOA110-1588 Notebook
GHOST RECON ADVANCED WARFIGHTER.
install a new graphic card of 128mb this will work
Sep 06, 2007 | Microsoft Windows XP Professional With...
BFG Technologies AGEIA PhysX 128MB GDDR3 PCI Physics Accelerator Card Logo
78 people viewed this question
Top BFG Technologies Computers & Internet Experts
David Payne
David Payne
Are you a BFG Technologies Computer and Internet Expert? Answer questions, earn points and help others
