Question about HP LaserJet 4100 Printer
Printer status offline - HP LaserJet 4100 Printer
  • 2 more comments
  • wnlee1112 Oct 25, 2008
    Printer connected via wireless continually says offline. Downloaded drivers to computer, added another "printer" as copy 2 and it prints everything, but when I shutdown, that copy 2 printer disappears.
  • mamlove Nov 04, 2008
    dosn't print and say offline
  • Anonymous Jan 19, 2009
    computer is offline
  • Anonymous May 10, 2009
    Printer status offline >> ?
    President:
  • 1,653 Answers
Make sure that the paper paths are all clear, open and close all covers and power off then power on again. If this persists unplug the netwok connectiona dn try connecting and printing directly to it via a parallel port or try unplugging the JetDirect from the printer. If this works then the JetDirect network card is at fault and needs to be replaced.
Posted on Aug 30, 2009
    Scholar:
  • 169 Answers
Well its esay...go to control panel,printers and faxes,there you will see the priner icon,rgt click on it and u will get an option use printer online.If this does not resolve the concern jst go ahead and uninstall and reinstall the printer f\drivers using thge device manager.If you wannt any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Status: offline/online
One way to make the printer go "on-line":
1. opening your "Printer & Faxes", the HP DeskJet F380 would be shown as an installed printer, by doing a right click, you would be presented with various options including making it go online.
There are two (2) areas that you can configure to make it stay always online:
i. in the same "Printer & Faxes", right click on the HP DeskJet F380, click on "Properties", in the next window click on the Advanced tab, tick "Always available", set Priority to "1", in the "Printer" tab, uncheck "Power Save".
ii. open your "Device Manager" (right click on "My Computer", click on Properties, click on "Hardware" tab, click on "Device Manager" button. Expand your "Universal Serial Bus controllers" (click on the + sign of the last entry), right click on each and everyone of your "USB Root Hub". Click on "Properties", click on "Power Management" tab, uncheck "Allow the computer to turn off this device to save power".
After each and every re-configuration it is of course required that you click on Apply/OK.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 09, 2008
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
  • 15 Answers
SOURCE: the printer will not print because the status is
This can occur if the usb has been jossled loose. I would unplug the usb, unplug the printer. Wait 2 minutes. Plug the usb back in and plug the power back in.
Posted on Sep 11, 2009
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Offline status
The most likely cause for this OFFLINE status on the PC is which interface is selected on the printer.
I think the printer defaults to Serial interface, so if you are using USB ensure you select the USB interface via the control panel on the printer, similarly if the connection is parallel ensure the parallel interface is selected.
If the connection is serial, ensure the cable is of the correct pin configuration and ensure the serial interface is set up correctly.
May 25, 2012 | TallyGenicom Tally 5040 Passbook Matrix...
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printer status always offline
go to your programs and select printer and faxes..rigth click your printer icon and select use this printer online..and if you want make this printer to be a default printer select also use this printer as default..
May 18, 2009 | HP DeskJet 3940 InkJet Photo Printer
Printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Apr 04, 2009 | Zebra 110Xi III Plus Thermal Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
HP LaserJet 4100 Printer Logo
1,168 people viewed this question
Seeker5211
Seeker5211
