Question about Refrigerators
I have a Maytag MFI2569VEQ1 refrigerator with a Serial Number of KY2224097. I replaced the Rear Board (I think it is the HV Board) because the refigerator portion would heat up to 51 degrees for a few hours then go back down to 38 for a day or so then warm up again. NOTE: The freezer never warms up at all. It always stays very cold. When replacing this board I need to have the Run-Code for this refigerator. The sticker on the inside of the fridge that is suppose to have the run code had been removed. I need the Run-Code to reprogram my new HV-Board.
  • 10,319 Answers
These people can help you and it is free of charge
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mfi2569veq1
Posted on May 22, 2011
Installed new hv board in maytag french door
With this board you should have also received a paper to program the unit. THe code you need is on the model number plate within the refer section of the unit your working on. I hope this helps.
Good Luck
Sep 27, 2014 | Refrigerators
Hv board needs to be replaced
Try www.searpartsdirect.com Or Give me your city and state I'll find you a local appliance parts supplier.
Oct 29, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I can't find the serial number. I think it was
Hello, Thank You for using FixYa. I will be helping you today.The serial tag is on the liner and cant be replaced look around, Side walls,Celing behind drawers behind lower grille its there some where! The only way its gone is if someone removed it.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Maytag Refrigerators
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
Aug 31, 2009 | Maytag MFI2568AE Side by Side French Door...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Dispenser Board
You must have a Kenmore. You can go to searsparts.com to get sears part number. HV board is not the same as dispenser board.
Jul 23, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator not working properly
dispenser board needs to be replaced. There was a recall on certain Ice 2O units. Call Maytag and see if your unit qualifies.You will need model and serial number.
Jul 23, 2008 | Maytag MFI2568AE Side by Side French Door...
Help! My Fridge is freaking!
Known common problem. If you call Maytag they will probably send you the parts for free. Will be new main and dispenser boards.
Jul 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
