Question about Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune electric dryer. When I replaced the power cord, I crossed two wires and it sparked and tripped the breaker. I properly connected the wires but no power to the dryer. Is there a fix? Is there an internal fuse that I blew and can replace?
  • 2 more comments
  • smithcurt51 May 22, 2011
    OK, how do you replace it and how much does one cost? Thanks.
  • smithcurt51 May 23, 2011
    Is this the same as the control board? How do you replace it?
  • smithcurt51 May 25, 2011
    yes
  • smithcurt51 May 30, 2011
    I checked the breaker and I have power to the dryer. I checked at the circuit board with my electrical meter and I have 120V at the Motor Drive Relay, but no power across the Heater Relay. What should I do next? The dryer is dead, and cannot get anything to power on, Thanks.
  • Maytag Master
  • 43,501 Answers
That should not have done anything inside the washer....you may have ruined the circuit breaker...before replacing anything in the dryer, confirm that you are getting 240v power to the back of the dryer. Also confirm that the wires going into the dryer have 240v and that there are not loose or burnt at the connection point.
If you have the properly power there.... then start looking internally and follow the current internally to see where the power is stopping at and what is not working...
An Electrical meter and proper knowledge of how to use one will be essential for you to properly troubleshoot this problem.
heatman101
Posted on May 23, 2011
  • 10,319 Answers
No the circuit board was shorted out upon crossing the two wires
It will need to be replaced dued to 220 volts going through it instead of 110 volts
Posted on May 22, 2011
No Heat
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
You can take your unit to nearby service centre if you find all the above are working fine.
Thank you !!
May 31, 2010 | Maytag Neptune MDE6700A Electric Dryer
My maytag neptune dryer is not heating and drying clothes
Apr 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Hello, my maytag neptune dryer runs, but will not dry. where do i find the serial # ?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. serial # should be inside door jamb!
Jan 01, 2010 | Maytag Dryers
Trips breaker and get "PF" on display even when not tripped
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Hope this helped and best wishes.
Sep 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
PF singal on dryer. Can not start dryer something electrical possibe pf power failer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Wont dry
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 03, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Dryer power cord
Need a multmeter to check voltage .. be careful 240v is very dangerous...red (120v) white (neutral) black (120v) hope it helps
Aug 13, 2008 | Maytag Neptune MDE6700A Electric Dryer
Dryer tripped breaker--shotgun blast sound
You may have a wire burn off the element and fall down to the base frame and cause a direct short. Turn you breaker off, remove the front and inspect for such a scenario.
Jun 02, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Electric Dryer
pf = power failure
do= door open
the dryer is tripping the breaker because your house wiring is probly not up to snuff, or you have a bad breaker. nothing you are saying sounds like a dryer problem, but could be a big issue with house (could be very bad, could cause fire)
May 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
184 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
