Question about Prestige Remote Start
I have a PRESTIGE KEYLESS ENTRY REMOTE ELVATOD APS2K4 and the sound is off, the doors wont lock but the starter works
2 Suggested Answers
  • 19 Answers
SOURCE: my prestige car alarm keyless entry will not
have you checked the 3 pin door lock plug at the alarm? it may be loose or unplugged totally.
Posted on Jul 29, 2010
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCodeā„¢ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In Ā· Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
Eclipse door locks
Sorry absolutly no idea without a play
Jun 05, 2013 | Cars & Trucks
My preinstalled prestige remote starter has worked twice at the dealers and i got it to work once. my question is do this combination sounds fimiliar for a chevy 1500. lock doors...lock door again, ho
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
Aug 03, 2012 | Prestige Appliances Vehicle Parts &...
I have a honda pilot with the prestige car starter and the panic alarm keeps going off when I open the door. I can not get it to stop so it has to go through its 2 minute cycle. any ideas on how to get...
That is your factory alarm. I will assume that this Prestige unit is a remote starter with keyless entry...and you are using the Prestige unit to unlock the doors. Apparently, the unlock wire is connected but, the factory disarm is not. You can turn off your factory alarm by unlocking the vehicle with the key.
Jan 25, 2011 | Prestige Remote Start
I'm not really clear on how this remote start works. It seems as though I have to stop the remote start (cut car off) in order to unlock the doors. I have a separate keyless entry and having issues as to...
It is a common problem with factory remote keyless entry (RKE) systems when a remote start system is installed. Many RKEs will not operate when the ignition is powered as the case when engine is running under the control of the remote starter. There is no easy solution to get around this safety feature if you insist on using the factory remote to operate the door locks. The best option is to use the MARS-22 to control you door locks.
Jan 23, 2011 | Omega MARS-22 Remote Vehicle Starter with...
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
My keyless remote for my 2000 jeep grand cherokee wont unlock the
go to autozone and use the remote tester on the counter to make sure that the remote itself is functioning or not, could be a dead battery. On some vehicles it is possible to reset the keyless entry by turning the ignition switch from off to run (right before the starter activates) 3 times or so, if you try this and the door locks activate then press the lock button on your remotes. good luck
Jun 03, 2009 | 2001 Chevrolet Blazer
Dog Chewed my Prestige car starter
one purchasing the new remote audiovox will send you an instruction manual on the steps to programming the new transmitter. it is fairly easy, and they will give you the number to there tech department that if you have any trouble they will also walk you through it. hope this helps
Feb 24, 2009 | Prestige APS686T Remote Start and Keyless...
Prestige Remote Start Logo
152 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
