Question about Audiovox SIRPNP2 SIRIUS Radio Receiver
My receiver just started to cut out on me. I get an audio pop and then loose my audio. If I jar the unit it will come back and sometimes will continue to play for hours. It's when I first turn in on that I experience the problem and remains intermittent until it finally makes a connection. I think It's a break in the wiring or on the pcb. I want to give it a visual inspection on the inside but can't figure out how to open the unit. Can you help.
Marty
  • pgunn2 May 14, 2009
    I have a similar problem in that the unit cuts out. This will happen regardless if it's in boom box, auto docking or home docking suggesting it's a problem in the receiver transmitter. If I apply pressure to the face it will come back sometimes for awhile and sometimes it will cut out immediately after I release it. I'm attempting to find out if it's better to send for repair or buy a new one. Does anybody know if this model is available?
Check your copper pin cylinder on the back of the receiver that goes into the cradle. The metal cylinder surrounding the copper pin can shave off or crack, causing these problems. If you can put your hands on another unit, you can replace this area with the parts unit. Unscrew the two screws holding the unit together and then slowly pry the unit apart, inserting a very thin blade and moving it slowly around the frame. Once inside, you will see screws holding down the area with the copper pins. You can remove this and put it in your receiver.
Posted on Aug 18, 2009
I have an Audiovox XM receiver that has no audio output. I tried another cradle and still no audio output. This is the second unit that has done this.
A IC has become unsoldered because of heating/cooling cycles. Basically, you can reflow (resolder using hot air or infrared) the board or you can buy a new radio.
Mar 18, 2011 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Unit shows 3 bars for signal strength yet the
This is a very old radio, and your antenna could be shot too. Try another antenna first.
Mar 01, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
My sirius portable radio keeps displaying "no antenna detected" but it's plugged in.
Several possiblities: one: antenna really is bad - borrow a friends Sirius or XM antenna and plug it into the base and see if the message goes away -if it does, replace antenna; if not, then your 'dock' or base could be bad - try removing and reinstalling the radio or try another base. If another base and antenna don't solve it, then the radio is shot and it's time for a new one. Customer service will ususally give you a great deal on a new XM radio IF you agree to keep it for 1 year. Let me know how it goes.
Jan 12, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
The audio cuts in and out intermittently
IT COULD BE ONE OF UR SPEAKER WIRE A TOUCHING AND GROUNDING OUT LOOK AT UR SPEAKER. AND IT COULD BE ONE OF UR SPEAKERS IS CONNECTED WRONG WITH THE POSITIVE ON THE NEGATIVE CHECK THAT OUT TOO ALL SPEAKERS NEED TO BE POITIVE WITH POSITIVE AND NEGATIVE WITH NEGATIVE
Jul 04, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
How do i unlock or modify audiovox sirpnp2
call up Sirius and see if they have any manuals for that model to see if they can unlock it for ya or just have Sirius erase the reciever and start fresh by them reseting Hope this helps
Cheers
Johnthetr870
May 15, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
I inherited a disfunctional SIRPNP2. The signal strength meter in the lower left corner always displays an "x". Anyone have an idea? Thanks
A couple of things to try. First, try pulling out the anntenna from the back just slightly. My SIRPNP2 gets a better connection that way. Also, check to make sure that your annenna isn't bad. If you have a friend that has Sirius, connect their anntenna to your unit. If it works, replace your anntenna.
Apr 24, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Sirpnp2 reciever gets hot and loses signal.
I had the exact same problem with Sirius radios. I bought two Kenwood DTS-7000S receivers and both were sent back for warranty. Of the two, they only fixed one but by the time I figured out the other was bad, it was out of warranty. Kenwood, along with the repair community state they do fix such units, they toss them out. The thing that gets hot hot hot is the part that receives the Sirius antenna inside your unit. If you're like me and have nothing to lose then I recommend doing some cutting with a dremel and adding a small computer fan. It just takes a light breeze to keep that part cool enough (but it does take some sort of breeze, convection is out). For a home unit, find an old A/C power supply and match it to an old computer fan of equal or less voltage. For car, find a fan that uses 12 volts or less. It's an easy fix, really!
Nov 04, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Pin in back of receiver broke off
If you can put your hands on another unit for parts, you can open it and replace your damaged pin with one from the unit for parts. It takes a little time and care but you can do it.
Mar 17, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
X act sirius streamjockey
any trees or build in the way no signal
Dec 16, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Antenna not detected
Call Audiovox support. After waiting an hour I was told the unit (pnp2) was faulty and I was to call customer service to arrange a replacement. Mine is on the way to NY.
Jan 15, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Audiovox SIRPNP2 SIRIUS Radio Receiver Logo
307 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
