Question about Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
My craftsman weedwacker 316.791190 bogs out at full throttle. i cleaned air filter, plug, carb, it runs great when i cover the air box with my hand though,
    President:
  • Craftsman Master
  • 1,545 Answers
When you cover the air bos, you are in essence, enriching the air/fuel mixture that is entering the engine. The carburetor does this when it is needed and when it is functioning properly. For the bogging problem, it is evident you need a small carburetor adjustment. I suggest turning the L mixture screw (the one on the carb closest to the engine) out (counterclockwise) 1/8 to 1/4 of a turn. The heads of the L and H mixture screws are unconventional type and some improvising will have to be done to enable you to get ahold of them to adjust them. I use a small plastic (22 gauge) automotive-type wire connector with a ring terminal end on it. I tap it down onto the screw head with a small ball peen hammer until it stretches around it. I then am able to turn it. Try the suggested adjustment for your high-speed bogging problem. And to further tune and adjust the carburetor on your machine, I highly suggest you look at the following tutorial.
http://www.zamacarb.com/tipspage.html
Posted on May 22, 2011
Echo pb 265l backpack blower bogs down at full throtle
Hi ryan...
You still have problems in the carb highspeed circuit..some debris in the passages...
BE SURE TO USE COMPRESSED AIR TO BLOW OUT THE CARB.
(be sure to watch the inlet valve seat, you can loose it and not even know it) Blow the carb clean in a box or something that will contain any part that may be expelled during cleaning.
Please take time to rate me
Bud
Mar 31, 2013 | Echo Garden
Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
May 10, 2010 | Garden
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
2004 sportsman 600, bogs down bad at half throttle.
Check that your choke is working correctly
Your timing may be way off as well
Mar 08, 2010 | Polaris ATV
I have a craftmens 25 cc weedwacker thats about 3
it sounds like your carb is out of adjustment and you need to adjust it. Look at the carb on your weedwacker, there is an idle adjustment screw somewhere on it and using either phillips or strait screw head and then carefully turning it clockwise go 1/8 of a turn at a time until the engine idles smoothly.
Sep 05, 2009 | Craftsman Convertible 25cc. Gas Line...
2001 kdx 220 starts idles great no power stalls out , floods
Use a hotter spark plug. They do have different heat ranges.
Jul 01, 2009 | 2003 kawasaki KDX 220 R
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer () Logo
4,148 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
