Kenmore 70s washer is failing to aggitate. it will fill and drain, but not aggitate
  • 35 Answers
Does it even try to agitate weakly?
Could be a stripped agitator, bad wig-wags (Common term for the solenoids that control the transmission) a broken wire or the trans, itself.
Posted on May 22, 2011
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
My washer will not pump out water or spin . it will fill, and aggitate. drain hose is not kinked
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 28, 2010 | Kenmore Washing Machines
Washer was working made a clicking/humming sound now the aggitator doesent work and wont spin. Still fills and drains.
your motor coupler is broke,tip the washer back and look between the motor and trans that is where the coupler is located-mike
Feb 19, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Jan 18, 2009 | Kenmore 20722
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
