Question about Motorola T5710 (22 Channels) 2-Way Radio
T5710 Will Not xmit, etc.
1st: My batteries are good. Contact is good. One radio will come on sometime. Display looks good, and you can use the menu button. When you go to xmit, the display blinks and will not xmit. It will receive, but sounds scratchy. Sometime when you turn it on it takes a few seconds for the display to appear. Now it does not come on at all.
Any Help????
Jerry
  • Patrick Patterson
    Patrick Patterson May 11, 2010
    Jerry are you sure that the battery charger is charging the battey. if not use a volt meter to check the battery and charger. If this is not the problem then I would consider taking the radio to a good service center or sending the radio to the factory.
    Patrick Patterson N5SLI
  • Motorola Master
  • 1,654 Answers
I know you say your batteries are good. However, the symptoms you are describing would indicate a bad battery. Just to be sure, you might swap the batteries between the units and see if the problem moves with the battery. If not, you are correct, the batteries are good.
The next issue would be an internal radio issue, such as the unit has gotten wet or moist, and corrosion is beginning to form on the board. OR it is possible you have a hairline crack in the component board and this is causing some of the traces to make a poor connection.
FYI: It is common with these smaller types of radios for people to put them in their back pocket and sit on them. This will many times cause hairline cracks in the component board, or will cause small components to pop off the board.
Posted on Aug 19, 2008
No transmit or menu
You can contact Motorola Directly then inquire where there is a service center nearby. They have the most updated list. The link to the toll free number is below.
http://direct.motorola.com/hellomoto/nss/contactus.asp
Aug 21, 2008 | Motorola TalkAbout T5530 2-Way Radio
Low pwr on xmit,weak rec,swr alert lite on xmit swr 1:4-1 on ch 20
you have no power because your radio is not tuned to your antenna.You get a new radio and put junky coax and a decent antenna and you expect it to work right. Get 75 ft of rg-213 and you will see a change.
Jan 08, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
Cannot set interference eliminator code on my second t5710
First check to see that your keypad is unlocked. You can lock/unlock the keypad by holding in the PTT button for three seconds. You will see a little lock icon when it is locked.
To set the code for a channel:
1. Press Menu until the CODE number begins to flash.
2. Press the + or - to select the desired code.
3. Press the PTT to save the code.
Note: You can set a different code ofr each channel using this procedure.
Zero (0) equals OFF.
If you continue to have problems, set both radios back to a very basic setting with all special featured turned off and see if you can communicate. Then add the desired features back in one at a time until you have what you'd like on both radios.
Best regards.
Oct 06, 2012 | Motorola T5710 (22 Channels) 2-Way Radio
Submerged one t5710 unit crossing a river; no longer transmits.
Probably not.
The electronics in the transmit / recieve circuitry (RF = radio frequency) work very differntly from those in the display and control circuits, which prob ablyexplains why the display works, but not the rest.
The major problem with water in RF circuits is that even after it dries out, it leaves a residue, or worse still some corrosion, which adversly affects the tuning of the RF circuits.
It may be worth trying to dry it out a bit more - put it somewhere warm but not humid like near but not too close to a central heating boiler, for a few days. However, I suspect it is now beyond repair.
Oct 07, 2009 | Motorola T5710 (22 Channels) 2-Way Radio
After being stored for over a year, one of my motorola t5710 radios does not work. They were stored without batteries or the rechargeable packs installed. Any hints.
electronics degrade with time there are corrosive cemecals in electronics the most comon one are the capacitors they leak and cause problems the newer the unit the less storage life it has due to inferior chinese parts good luck!
Sep 02, 2009 | Motorola T5710 (22 Channels) 2-Way Radio
Won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
May 31, 2008 | Motorola T5710 (22 Channels) 2-Way Radio
Moto T5710 Disassembly - Transmits Carrier Only. No Modulation.
Hello bwilliam. Batteries can give you a false reading. Check your batteries under load. Good luck.
May 22, 2008 | Motorola T5710 (22 Channels) 2-Way Radio
Radio Communications Logo
146 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
