Question about Digidesign Mbox External Sound System
MBOX2 only getting mono sound
Hi, I can only hear through one side of the headphones when playing through the Mbox2. I've checked the headphones on another system and they work fine. I'm wondering if something has come loose inside? Is it expensive to send it for repair? thanks
  • sharpebill Sep 18, 2008
    Hi ! I can hear out of 1 side of the head phones only; the head phones work fine w/other equipment!
    Problem Solver:
  • 13 Answers
Check the adjustments in your mbox is there is any option to move the noise left and right if there is one so put it into centre
Posted on Aug 17, 2008
SVE1112M1E headphone problem
When your PC plays music or video, what type of sound output do you get; normal or robotic?
If its normal, you may have to test/try out another headphones and connect/plug in to your PC and listen once again to the output sound.
Is it same as your previous headphones is; sounding robotic or is it normal?
Normal sound output in the new headphones (not your previous headphone), you know the answer.
Robotic sound output with the second headphones? You mahave to reload the drivers if this'd help.
However, simply hope problem is not with your PC's sound jack
Oct 17, 2017 | Computers & Internet
Right channel cuts out when I increase the volume
Blown or defective Headphone Amp IC or alternatively a defective Pot. Either way only AVID can fix it for you.
Outside parts and service is impossible.
Oct 03, 2012 | Digidesign *mbox2...
Stanton STR8 150 turntable right output not working
Check the connections at the rear of the cartridge. Something may have worked loose while in storage
Oct 02, 2012 | Stanton STR8-150 Turntable
Rear Entertainment Systems plays sound on right side only
Using the wiring colors check the head unit output with a test speaker.
Apr 13, 2017 | Audiovox Car Audio & Video
Dell Inspiron 6400 E1505 audio not working.
Try system restore to straighten out registry to play audio..
Apr 01, 2012 | Dell Inspiron 6400 Notebook
Sound pops an crackels how do you change fse on mini mbox
Fuse would have NOTHING to do with the problem. Make sure to use balanced audio lines... XLR or TRS to mics or other devices.
Aug 24, 2011 | Digidesign *mbox2...
The headphones do not play any sound... As a matter of fact, if you are in a quiet room, you can ALMOST hear that something is playing, but no matter how loud you turn up the source, it is still so low...
cdobmusic,
I am not entirely familiar with these headphones, other than knowing that the sound quality is amazing. However, I do have a few suggestions for you. First of all, if these headphones have noise cancellation, you may need to check the batteries. It is possible that it needs batteries in place for the speakers to work at all. Secondly, double check your connection to your device and also check the sound levels on your device. I know, it sounds basic, but sometimes that's why we look it over. If neither of these work, call up Monster Cable. They stand behind everything they put their name on for life. Unless you've modified your headphones or gone swimming with them still on your head, they should replace them if there is truly a problem. good luck!
~Kudos~
May 03, 2011 | Monster Cable Products Monster Beats By Dr...
I can only hear one side of my headphone with the Samson S-Amp! wheni pull the headphone cable out i can hear on both ears. what kind of connection do i need to listen in stereo?
Are you using a STEREO input cable? Is the source of the audio stereo? The stereo cable will have three connections on the plug... the sleeve, the ring and the tip.
If you only have mono source or using a mono cable you will only get sound in the left headset. Pulling the plug part way out will sometimes contact both connection so you will hear both.
If your source is mon, you will need a special cable that connects the mono signal to both sides of the input plug, that is the ring AND the tip.
Mar 29, 2011 | Samson Samp Headphone Amplifier
The recording level to my Mbox is very low for some reason. I am running Pro Tools LE and I have a shure 87a microphone. Every time I attempt to record a track, the input volume is incredibly low...
Make sure you turn the Phantom power on the Mbox2 on as the Shure 87A requires it being a condenser mic.Make sure you use XLR mic cables. These are just things to check on.
Jan 29, 2011 | Digidesign *mbox2...
My mbox2 will not install no more on my hp windows7 64bit get message Proot8 not vaild exec of win22. tried to install with hp support but could not
There has been a virus (nesky) that pertained to Win22.... if there is a chance you have that scaan for it first.
If that isn't the problem POSSIBLY an anti-virus program or anti_spyware is blocking it. Disconnect from teh internet and disable ALL these anti programs and try installing the Mbox2 again.
Last method would be to try installing it in SAFE mode if nothing else works.
Jan 05, 2011 | Digidesign MBox2 USB with Pro Tools 8 LE
Open Questions:
Digidesign Mbox External Sound System Logo
287 people viewed this question
Top Digi Computers & Internet Experts
doggzzz
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
