Question about Zoom Computers & Internet
I have a Zoom X3 modem and would like to be able to access devices on my internal network from the WAN. I have configured the "virtual servers" section to map the incoming ports to the IP address of the device I want to access. I have alos set up the IP filters to allow the incoming packets through. So far, I cannot access the internal device from the WAN, unless it is port 80, which is a default and doesn't need to be set up. Zoom tech support has been no help so far.
Orbixx
  • 133 Answers
SOURCE: Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Posted on Sep 07, 2007
  • 4 Answers
SOURCE: Port Forwarding for Apache Server
Hi Robmoll,
Let's get a little bit more in detail. I'm doing the same exact thing you are trying to do with a D-Link DI-624 and I'm using NO-IP instead of DynDNS. I'd like to ask you a question, if I may, what are you actually seeing now using port 80 and how did you disable it? Can you connect another PC to the same router (making a small Home Network) and test locally your Apache and eventually your web-page by typing something like this "http://192.168.0.101/"? Are you already able to see your router from the "outside" trough port 8080? Are you specifying your "private" IP in the port forwarding setting of your router? Do you mind showing a snapshot of your port forwarding settings? Here is mine; you see two different IP's because there are two PC connected.
Regards,
GiBi
Posted on Oct 27, 2007
  • 556 Answers
SOURCE: X6 modem router
Your ISP probably has some setup requirements from the modem side of the router that will need to be identified.
Users guide is here which may help
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
for general wireless security see
http://www.fixya.com/support/t281214-wir...
Posted on Dec 06, 2007
  • 556 Answers
SOURCE: Internet access
A router by design is to provide a connection between two different networks -- separate networks with different IP address ranges. If this is a corporate network or someone else's network connection of a router may be undesirable or forbidden by their policies check before proceeding. To add additional devices to a wired network can often be achieved with a switch or a hub instead of a router which is far less complicated. You have indicated there is a DHCP server to supply network addresses on the existing network making the switch or hub approach potentially available. If however you are attempting to connect a router to a single port modem device to your internet service provider this may well be the correct answer. If you are attempting to separate portions of your operations for security reasons this may be part of a reasonable approach.
In general to access the internet you need a unique IP address belonging to the network to which you are attached to operate on that network. The address range of the LAN side of the attached router must be different than else where in the attached network. So the 10.2.2 network assuming a subnet mask of 255.255.255.0 must be unique to your router and not used elsewhere for other routers in the rest of your network. In addition you need gateway address and NAT (address translation) services to share the single internet address available to the internet in most home/small business environments from your router through the necessary routers all the way to the internet service provider's access point for your operation. You also need access to DNS servers to resolve textual names like fixya.com to IP addresses to route messages. Without any of the above your connection will not work. Some environments block direct access to the internet and require the use of proxy servers -- this could also be a requirement in your environment -- the configuration to access those can differ by facility and must be answered by the local administrative staff.
I hope the above helps
Posted on Jan 03, 2008
  • 84 Answers
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Posted on Feb 11, 2008
After connecting my Dynex DX-E402 wifi router to my desktop computer and running the Quick Setup on the router website I still cannot connect to the internet nor will my Netflix-ready DVD player connect to...
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
Nov 03, 2017 | Dynex DX-E402 Router
Error code 651
Error code 651
This error corresponds to an error in a modem or any other connecting device
Try the folloging the instructions below:
If this is a dial-up connection, and you are using a supported external modem, turn off and then restart the modem. Close and restart Network and Dial-up Connections, and then redial. If the problem persists, try connecting at a lower initial speed. See To change the maximum modem port speed. Make sure you correctly configured your modem for remote access. To check your configuration, see To configure a connection. If this is a virtual private network (VPN) connection, you might have specified an incorrect TCP/IP address in the connection configuration, or the server that you are trying to reach might not be available. To determine if the server is available, see your system administrator.
Oct 18, 2010 | Computers & Internet
How to set up wbr-3406 tx router with dsl modem
Take an Ethernet cable, and connect the Ethernet port on the DSL modem to the WAN port on the router.
Take another Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer.
Now, you should be able to web-surf.
Access the web-server inside the router, and run the "Wireless Network Setup Wizard", to configure your wireless networking.
Jun 24, 2010 | CP International WBR-3406TX Wireless...
Wanting to make my laptop wireless connection
Hello.
Connect the MODEM (device you received from your Internet Serivce Provider that gets the Internet signal) to the router via the WAN port. WAN stands for Wide Area Network and this gets you out to the Modem and then to the Internet.
Ports 1 and higher are for computers and network printers that you can directly connect to your LAN - Local Area Network.
To secure your connection, you will need to configure your router and you will need to connect your laptop to the router (either wireless or via one of the numbered ports on the back of the router), open a web browser and enter the IP address of the router.
Since you did not put the model of the router, I cannot give you specifics on how to secure the connection. You can go to the D-Link web site, find your router, download the manual and it will walk you thru the settings.
Basically, you will be entering a WEP key (a set of letters and numbers that you know) to allow only wireless computers that have this key.
Apr 30, 2010 | D-Link DI 514 Wireless Router (DI-514)
My computer can see my router but can't get past my modem
1. delete all the saved networks from your computer
2. Make sure that firewall id disabled in computer
3. Tried to set your wireless as unsecured network and try to connect
4. Uninstall/Reinstall wireless adaptor and tried.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Can't access Config Manager for Router - Zoom x6 5590
- Reset the router (10 seconds)
Access the configuration page (10.0.0.2)
or
Try to assign a static IP address to the computer (IP 10.0.0.52 Automated SubnetMask, Default gateway 10.0.0.2)
(Note: Make sure that your computer is physically connected to the LAN ports of the router and your modem is connected to the WAN or Internet port.)
Mar 08, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
DSL connection not being shared by Linksys RV042 Dual Wan router
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
Feb 24, 2009 | Linksys RV042 VPN Router
Router no connecting to the internet
You need to configure NAT on the router to permit the entire LAN to access internet
Example.
LAN Segnment is 192.168.1.0/24
1. Create an access-list to identify the local segment
2. Configure the Nat interfaces properly (NAT-INSIDE, NAT-OUTSIDE)
3. do the NAT configuration
i.e ip nat inside source list (ACLNUMBER) .....
Dec 08, 2008 | Computers & Internet
Need to network SG300 Firewall and Qwest (Motorola) 3347-02 Modem
The modem needed to be set to a 192.168.x.x network, and the SG300 Firewall WAN port needed to be set to a dummy IP on the same network for it's IP, and the specific 192.168.x.x address for the gateway and DNS.
Nov 05, 2008 | Cyberguard SG300 (00852503000366) Firewall
Configuring ppoe connection with zoom modem
Your external (WAN) IP should be set to DHCP for most ISP's. Your internal IP will be the default gateway for everything in your LAN to get sent to. If you can log into the zoom with your browser, try that IP address for your gateway. If not can you let me know some more details on your zoom model.
Aug 02, 2007 | Zoom (56600000) DSL Modem
Computers & Internet Logo
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
