Question about Delta Cycle Rothko Rolling Bicycle Stand
How does the saw blade slide along the rail. It is a delta model 33-060
rowdy45176
  • 2176 Answers
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
Posted on Mar 14, 2009
efs_perpends
  • 1996 Answers
SOURCE: Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Posted on Mar 24, 2009
efs_perpends
  • 1996 Answers
SOURCE: Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Posted on Mar 25, 2009
SOURCE: Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Posted on May 15, 2009
  • 9 Answers
SOURCE: Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Posted on Jun 22, 2009
Where do I find a guide rail for a Rockwell 4500 circular saw?
If I'm not mistaken, that model saw is already discontinued. I suggest you call or email Tool Parts Direct or Delta. I only have band saw machine, I'm thankful that bandsawparts.com makes aftermarket parts for all brands of band saw.
Jul 17, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
How to change blade
You can download manual on bandsawmanuals.com or try to search on google , make sure to key in the model number of your bandsaw. You can also follow instructions from this article. How Do You Change Band Saw Blade
Jul 10, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
I have a delta 34-444 table saw, is it a right or left tilt, or how do i find out?
Left-tilt, right-tilt refers to the direction the top of the blade can be tilted when it is not straight up and down. There will be an indicator on the front of the saw, normally pointing to zero. When you adjust the blade away from zero, if it tilts to the left, it is a left-tilt saw.
Feb 05, 2013 | Delta Machinery Delta 34-555 Sliding Table...
My LS1013 saw kicks back toward the end of cut, it's worst with wide boards. How can I correct this? John L. Edmonds jledmonds@bellsouth.net
John, These sliding saws are a lot like radial arm saws except it is possible to pull the slide forward, then lower the saw and cut while pushing. Some people operate their saws like this, but it's dangerous unless you use both hold-down clamps and board has no warp. When operated in this manner, the blade is pushing the board up. If the board has any room to move, it can kick. This may be what you are experiencing. On the other hand, if you operate the saw like a radial arm saw, that is, by pushing the slide all of the way back, lowering the saw and then pulling the slide toward you to finish the cut - then the blade is pushing the board down, which is safer, especially if you don't use the hold-downs. However, if the saw is not correctly aligned such that the blade is not quite parallel to the slide, then the back of the blade will tend to lift up on the board on one side. You can test for this mis-alignment with a dial indicator. Just slide the saw forward or back as the indicator rubs along the surface of the blade. Since the saw is moving along the slide, the indicator should move very little if the blade is parallel to the slide. good luck, Al K
Jan 19, 2011 | Makita 10" Dual Bevel Sliding Compound...
Delta saw model no. 28-245 saws a taper form top of wood to bottom why does it not saw a stander line Delta saw model no. 28-245 s/n 91B1335
Sounds like your table is tilted. Put a small square on the table against the blade, then adj the table to it. If that is not it, then the blade guides are off up and down, back off all the guides, wheels, turn the blade by hand, get it tracking in the center of the tire, then bring the bearings up the blade, don't push it , just touch it, then bring in the guides, again, make sure it doesn't push it, the guides stop it from going off, it should track by itself. Hope this helps.
Feb 05, 2010 | Delta Saws
The front and back of the blade are not square to
use a square to sure up your blade so you are at a true 90 degree
Jan 16, 2010 | Delta Machinery 10" Left Tilt Contractor'S...
I need to get a replacement saw blade guard for an old Rockwell Delta Radial arm saw. 12'' Blade Serial # MX3 2843 I don't know what model number this saw is to get the right part.
you can try going to Dewaltservicenet.com and locating it that way but with only the serial number it would be impossible. Is there any numbers on it to indicate the model or partial model and you can pull up breakdowns that way.
Dec 10, 2009 | Delta Saws
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Delta Cycle Rothko Rolling Bicycle Stand Logo
23 people viewed this question
Top Delta Sport & Outdoor - Others Experts
Are you a Delta Sport and Outdoor - Other Expert? Answer questions, earn points and help others
