Question about Kenmore Washing Machines
I have a kenmore model 110 top load washer that does not agitate properly. it is very weak. What are the correct ways to troubleshoot, diagnose and repair this?
  • 35 Answers
First thing to do is remove the agitator and see if the splines (ribs) on the agitator or bushing are stripped. The ribs are only plastic and meant to shear under stress to protect the transmission.
Earlier washers have a nut or cap on top of the agitator (may be reverse threaded).
Newer units, the agitator just pulls off.
Posted on May 22, 2011
I have a kenmore heavy duty 80 series top load washer model 110 and it is no longer agitating. I think it is the dogs that need replacing but the white portion of agitator itself looks a little worn. ...
well i would recommend repacing agitator and agitator doggs ... get complete model number off washing machine data place got to sear.com and select partsdirect enter model and order parts they will send directly to you...
Jan 28, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 110. (full number is 110-82984810) It has a "ratchet/screw" type agitator. The big fins on the bottom part agitate back and forth, but the center piece no longer moves in a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082984810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
For future reference you might also want to review / print / save the following Whirl[pool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Dec 26, 2010 | Kenmore Washing Machines
The agitator won't work, and the button under the lid fell off. What can we do to fix it, or would it cost too much to fix it?
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
IF THIS IS A BASIC KENMORE / SEARS TOP LOAD, DIRECT DRIVE WASHER THE PROBLEM IS LIKELY A LID SWITCH. (EASY AND INEXPENSIVE TO FIX)
I'D NEED TO KNOW THE BRAND AND MODEL NUMBER TO BETTER SUGGEST A SOLUTION.
Aug 13, 2010 | Washing Machines
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
How to disasemble model 11020722
The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem.
Can you describe exactly what you want to disasemble??
Jan 25, 2010 | Kenmore Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Jun 22, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
246 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
