Question about Neff S51T69X1GB Dishwasher
Model Neff S54M45X5GB/01 Built in dishwasher. The
Model Neff S54M45X5GB/01 Built in dishwasher. The machine makes a churning noise. Water laying in the bottom Filters clean at the bottom down to the impeller. The cold ilet filter is clean. Cannot get any programme to work. Just a churning noise. Little water going in then discharges down the drain. HELP
  • 883 Answers
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Posted on May 26, 2007
TaPuna
  • 70 Answers
SOURCE: How do I reset my dishwasher
Sounds to me like you have put the dishwasher into flood mode, this happens when there is water in the base panel, try leaning the dishwasher back and see if any water comes out. :)
Posted on Sep 07, 2008
  • 11 Answers
SOURCE: dishwasher not draining (neff slimline intergrated)
you could try liquid plumber but i wont guarentee anything. However, It could be a problem with the draining mechanisn and not a blockage. Also if the liquid plumber does work I would run the machine with nothing in it to rinse all the chemicals out
Posted on Dec 30, 2008
  • 228 Answers
SOURCE: my neff dishwasher will not fill will water and
i if it doesnt fill with water check it is actually draining is there water in the tub etc?if it cant drain it wont fill or complete the cycles,this is usually a blockage in the pump the handbook tells you how to deal with this problem.
Posted on Aug 05, 2009
SOURCE: Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Posted on Aug 26, 2009
I have a Neff Dishwasher S5446x0/29 FD 8109 460056. It started making a whirring noise and when I looked it was not emptying the soapy wash water. I stopped the machine and manually drained the water out....
if the pump is not emptying properly it will think its still full, they have a sensor in the bottom that tell the machine that the system is empty and to begin next cycle.
Jun 27, 2017 | Neff 24 in. S5456 Built-in Dishwasher
My built in Nett Dishwasher - model no. S54M45X5GB - The water doesn't drain. We have tried solution to clear pipes but the water still isn't draining
You may have a bad pump but..... you should remove the hoses from the drain pump and see if you can turn the impeller by hand. Since this is an induction current magnetic rotation pump (lousy design in my book) any small bit of debris can lock the pump up. Remove the debris from the pump reconnect the hoses and see if it will drain.
You can see your pump here:
http://www.espares.co.uk/part/dishwashers/pumps/neff/s54m45x5gb%2f01/p/1537/1126/0/1122140/503469/dishwasher-drain-pump.html
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Dishwashers
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher not working. Start button works ok as
It sounds as though the Anti-flood device has kicked in,could be due to a leak under the dishwasher,it will need to be pulled out and investigated.
I would also check that there is water at the hose to the machine.
Hope this helps.
May 21, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
Jan 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff Built in Dishwasher
take top off then side panel and hinge is exposed. to expose the part of hinge on door, take outer panel off door - just held in by screws down each side
Jun 26, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the problem...you may have a defective timer or your outlet hose is clogged or kinked.
Feb 10, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff S51T69X1GB Dishwasher Logo
71 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
