Problem faxing i am trying to fax and the problem is that the fax machine comes back with NO REC.PAPER 010 please help!
  • 2,120 Answers
What make/model fax?
Posted on Aug 31, 2008
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Jun 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
1 (for off)
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
I cant recive any fax
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
there is no previous post for your problem please restate.
Are you trying to Rx a fax and it's showing wrong size? do you have a manual? I can give you a link for a free one.
Aug 28, 2008 | Canon FAXPHONE L80 Laser
Panafax dx-800
Press Function, then 7
Press 4, then Copy/Set
(it should ask for a fax parameter, the one for the key sound is 010)
Enter "010", then Copy/Set
Set the parameter to "1" for Off, then press Copy/Set
Press Stop to exit back to the default screen
Jul 23, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
I have a Panasonic uf-4100 that is printing,sending and receiving with a thick black line down the middle
We have a Panasonic UF-4100 and i am having problems faxing, it comes up with NO REC.PAPER 010
Jul 15, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Error message - "check Rec. Paper"
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Mar 31, 2008 | Muratec M1250 Fax
Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Dec 13, 2007 | Canon FAX-L350 Plain Paper Laser
Can not receive faxes
On the front of your machine, you will see a button that says "In/Out". I bet someone hit that by mistake, turning off auto-answer.
Nov 05, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
21 people viewed this question
