Question about Danby DDW497W 22 in. Countertop Dishwasher
Portable dishwasher dished just haven't been coming clean for the past two weeks. sames cycle, number of dishes and silverware, sames cascade liquid detergent but dishes just don't get clean. no water back up in hose on in the sump in the bottom--not really. help.
  • Danby Master
  • 1,902 Answers
Hello & Welcome to FixYa
The problem seems to be with the float switch assembly that is bad and needs replacement. However, before replacing this part you can run a empty cycle with 3 cups of vinegar inside at its hottest temperature, after this clean the drain filter assembly. If the problem returns then replacing the float switch assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on May 22, 2011
Items are coming out looking like they have a coating or film on them. I first thought it was a 'fluke' w/ the detergent (Cascade powder), so I ran a rinse cycle w/out anything. The glasses,...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jul 12, 2011 | GE Dishwashers
Whirlpool Gold dishwasher not cleaning dishes. It runs through the cycles and rinses, but dishes are not completely clean.
I had a similar problem with my last two dishwashers, with food still left on the dishes at the end of the cycle. What a nightmare. The most recent dishwasher is new, now the problem is solved. Here's what the manufacturer told me. Pour white vinegar (approximately 2 cups) into the dishwasher and run through the cycle. Buy some Cascade Complete and only use this type of soap for the dishwasher. Make sure you run a cup or two of the white vinegar through the dishwasher cycle once a week. My dishes are now clean and clear!!
May 26, 2011 | Whirlpool Dishwashers
Etching on the glass ware and the dishes don't come clean.
Dishes may not be getting enough rinse water. Had the same problem before I replaced inlet valve. My fisher packel was 3.5 years old before I replaced the inlet valve due to a knocking noise, but It still ran through cleaning cycle without any alarm codes.
May 17, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Dont clean my dishes
Try cleaning out your drain because it could be clogging up and this can cause it not to clean the dishes.
May 19, 2009 | Tappan MDB531RF Dishwasher
Dishes come out with a white, chalky film, not very clean.
are you using palmolive eco liquid detergent? if so - google "palmolive eco white residue" and you will find out that your detergent is the culprit. the solution is to use 1/2 cup of vinegar in your rinse cycle and soap dish and STOP USING PALMOLIVE ECO!
May 02, 2009 | Maytag MDB8551 Built-in Dishwasher
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
Silverware becomes cloudy and is difficult to polish
The new water-conserving dishwashers, including the LG LDF 7811 are very sensitive to the dishwasher soap that is used.
If you notice white staining beneath the soap dispenser at the end of each full wash and possibly undissolved powder remaining in the dispenser, I recommend you stop using that powder and buy a box of Electrosol or Cascade powder and use it in place of what you currently use. Avoid using gel or tablets in all dishwashers.
I experienced very similar problems with the LDF8812 that I personally own. First step to fix was pulling the filter (10 phillips screws) rinsing the filter as best possible, remove all debris. Replace filter and spray arm.
Place a bowl filled with white vinegar in a bowl on the rack of the empty dishwasher. Run a quick wash cycle to the end.
Look closely at the RinseAid cap inside the door, remove it and turn the little dial to a lower number. Over time, adjust it up if dishes are not drying properly.
Use the dishwasher normally - do not overly pre-rinse the dishes because the food particles are actually used during the wash cycle to help clean the dishes. Also, do not over load the dispenser cup with soap. A Tablespoon will do it. If you run out of the rinse aid, feel free to use white vinegar.
Oct 21, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Residue on dishes
Use less soap.
Jan 13, 2008 | Dishwashers
Danby DDW497W 22 in. Countertop Dishwasher Logo
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
