Question about KitchenAid Pasta Roller & Cutter Set Kfetpra
The first time I used my new pasta roller I seem to have burned up something in my Kitchenaid mixer. What happened?
  • Anonymous Mar 17, 2014
    I have broken the brass or copper drive shaft in the pasta roller of kitchen aid KFETPRA.It is a small bolt obviously designed to protect the mixer, I broke it by trying to clean rollers with a cloth that got caught. Where can I get this part
First Question that comes to mind, is the motor even running. If it is and there is nothing visible moving, you probably stripped the gears in the head of the unit. If the motor doesn't run, the brushes may have coincidendally worn out. Need more information. Reccomend taking the top cover off while it is unplugged and checking the gears and brushes. The Plastic gear (When I got mine) was a bit pricey, but a lot cheaper than a new mixer. If you wore out the brushes, You may just want to consider a new machine since you evidently got a lot of use out of it. Almost everything is replaceable in the mixer
Posted on Mar 04, 2012
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
The knob on my kitchen aid pasta roller keeps getting stuck and i cant change the setting i need to be at
It needs either oil or the gear has slipped. A machine repair person, such as a sewing machine repair might be able to help you out for a small fee. Good Luck!
Oct 27, 2013 | KitchenAid Kitchen Aid Ravioli Pasta...
Brass shearing pin
All of the KitchenAid pasta attachments are considered non-serviceable. There are not any parts available. You only option would be to buy a new pasta roller. KitchenAid has recently made the roller available by itself so you do not have to purchase it in a whole pack.
We carry the pasta roller, here is a link to the item on our website:http://www.mendingshed.com/kpsa.html
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 12, 2013 | KitchenAid Food Mixers
Kitchen aid pasta roller is locking up
You will need to follow your nose and carefully dismantle it to see where the fault is. As far as I am aware Kitchen Aid supply no parts for this accessory, it comes as a complete unit only.
Mar 24, 2013 | KitchenAid Pasta Roller Attachment
Hi, you may have a broken shear shaft. Here is a link to replace it.
http://www.ebay.com/itm/KitchenAid-Pasta-Roller-Attachment-KPSA-Repair-DIY-Hex-Shear-Shaft-Replacement-/281539451678
It also comes with instruction on how to replace it.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
Where can i get gears for kitchenaid pasta roller
Not a solution, just want to echo the problem. There are solutions for the shaft, but when I opened this up I found a stripped nylon gear attached to the shaft. Kinda sucks: I recently replaced the nylon worm gear in the mixer, now I have to do the same in the spaghetti cutter. I can't find the part or any mention of it anywhere.
Jan 17, 2013 | KitchenAid Pasta Roller / Cutter Set
KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
this is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Oct 13, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid Pasta Roller & Cutter Set Kfetpra Logo
347 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
