Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Raise Bicycle Handlebars How to Adjust Your Bike Handlebar Height How to Adjust Handlebars Tech Talk How to Raise your Handlebars
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
You need to loosen the neck of the handle bars with a anlenwrinch.After that you will be able to adjust the hieght of the handle bars by lifting the top of them.
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
the handle bars run thru your neck in the center, you should find a hex head bolt inthe center of the neck, loosen it then pull the handle bars up, be careful not to unscrew the entire bolt in the neck
