Question about Diamondback Serene Citi Classic Women's Sport Comfort Bike (26Inch Wheels)
I have a diamondback serene citi; in the highest gear, it's still too easy to pedal. Any way to increase the tension?
  • 843 Answers
The "highest" gear would be the one where the chain is on the smallest cog of the back wheel and on the largest cog by the pedals. I mention this just in case you don't actually have it in the highest gear. But if you do, then no, other than dragging the brakes, you can't increase the pedal effort. (If this is one of the bikes that automatically shifts the gears for you, then yes it would be possible by changing the weight of the flywheel - but I recommend against it.) Many adult riders who haven't been riding much for some time experience this same desire, because they expect the pedal effort to be higher. I would guess that you are expecting to get some exercise. Biking is a good choice, but it takes time to warm up to it. Using a high pedal effort too soon will injure your knees and ankles. Better to take it easy, increase the time and distance and you find that you cadence (the rpm of your pedals) will naturally increase. Check what cadence you tend to find comfortable now. A healthy cadence is about 70 rpm. But you will probably find 40 rpm more comfortable at first. Good luck, stick with it. :) (By the way, most experienced riders find that those bikes the shift automatically actually give to high of a pedal effort - they tend to target a cadence of about 50 rpm.) I hope you found this helpful and encouraging. Al K
Posted on May 22, 2011
Testimonial: "Thanks! This was vey helpful!"
    Brigadier General:
  • 8,546 Answers
Yeah, let air out of your tires. Tighten the brakes. Climb hills.
Seriously, I don't think you want more effort for a given pedal stroke but more distance for it. The only thing you could do mechanically to increase the high end would be to get a larger chainring or smaller rear cog(s).
http://bestcomfortbikes.blogspot.com/2011/04/diamondback-dscwscb.html
The 42 large chainring and 14 highest gear in back gives you 3-to-1 revs per stroke. I imiagine you don't really NEED the 34-end of the 14x34 cassette. An 11-tooth rear cog is commonly available so a new cassette with, say 11x26 (or less) might do it for you. They're cheap and easy to have installed. Many shops will take your low-use cassette in trade.
That would be just under 4-to-1 wheel rotations per pedal stroke. The crankset is 'compact' so it would accept a 50-tooth chainring. The jump down to the 32 would be to large so other things, perhaps the whole chainring set or maybe replacement with a double chainring 50x36. WAY more expensive.
The "women's" frame style limits how big a chainring this bike will handle because the front derailleur can only go so high.
If this bike is way too easy for you perhaps you should consider getting a better road bike and riding with the boyz in lycra.
Diamondback 460ub tension adjustment? how?
http://www.bing.com/videos/search?q=diamondback+460ub+tension+adjustment&qpvt=Diamondback+460ub+tension+adjustment&FORM=VDRE
May 22, 2015 | Diamondback Cycling
How do you level the seat? It is angled down in the front and I'm always slipping forward.
Underneath the seat is an adjustment. It is right underneath the seat and has notches in it..
Apr 06, 2015 | Diamondback Serene Classic Women's Sport...
Where should I set the gear and the friction when casually riding my Serene Comfort on level ground?
The above doesn't answer the question as I have recently purchased the same bike. I was wondering the same thing. Should I be at + or - (which gear wheel should it be on 1, 2 or 3?)
Jun 24, 2011 | Diamondback Serene Citi Classic Women's...
I have a diamondback serene women's bike, can't shift into 3rd gear. grip turns extremely hard and then if I get the shifter to 3rd, the gears on the bike just click. have to ride it really hard and...
Many possibilities, including derailleur outer limit not correctly adjusted, derailleur not mounted correctly, tight bend or friction in cable. Talk to the store manager/owner about correcting your complaints or find another shop or a bike co-op. If the bike is a major brand from a bike shop (Trek, Giant, Cannondale, etc.) try going to their website, look for Customer Service/Support and enter a complaint.
May 23, 2017 | Diamondback Serene Citi Classic Women's...
Looking for fenders for a Diamondback Serene Citi Classic, 17" frame and 26"wheels.
Order at your local bike shop, fenders are usually universal, not brand specific just need the right size, and they can install them too for a nominal fee. They usually are in stock.
Sep 28, 2010 | Diamondback Serene Citi Classic Women's...
How do I operate the gear shifters on a diamondback sorrento?
Here's a great article on that subject. The article covers virtually any multi-speed bike, including yours. One thing the article leaves out is that in order to shift, the chain must be moving, which means that you must be pedaling. But it works best if you are pedaling very lightly.
http://bicycleuniverse.info/eqp/gears.html
Jun 30, 2010 | Diamondback Sorrento 26" Mountain Bike
I have a diamondback wildwood citi bike that needs to be disassembled for shipping. How do I remove the pedals?
shifter on bolt near those arms and twist they might b a bit stiff so chuck on some wd 40 lube
Nov 13, 2009 | Cycling
Looking for
This seems like the best they have:http://www.diamondback.com/downloads/owners-manuals/ unless you try phoning them at 253-395-1100 and asking for customer service or writing them a letter at DiamondBack Bicycles 6004 South 190th Street, Suite 101 Kent, WA 98032 Hope this helps.
Aug 18, 2009 | Cycling
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
Diamondback Serene Citi Classic Women's Sport Comfort Bike (26Inch Wheels) Logo
357 people viewed this question
Top Diamondback Cycling Experts
Lloyd Carter
Kelley Jones
Kelley Jones
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
