Question about Frigidaire Washing Machines
Frigidaire Washer Mod# FWS223RFS0, SER # XC81198815, Machine fills, drains but does not spin in spin cycle. I checked by bypassing the lid switch. Not sure if it aggitates, didn't fill completely
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 1894 Answers
SOURCE: washer will fill and run
Could be a bad motor, or something stuck in between the tubs, like a nail, wash cloth, sock.
Try to turn the belt both ways with no power on, unplug the machine, before you start. Take the Belt off, then turn the motor pulley , then turn the transmission both ways. All should turn freely.
On this model i believe you can just tilt the machine back to do all this.
Posted on Mar 15, 2008
jsrock516
  • 5911 Answers
SOURCE: will not drain or spin
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 18, 2009
  • 50 Answers
SOURCE: i have a whirlpool washer model#LSQ8520JQ0.
More than likely it is the clutch or transmisson. Since it drains and agitates we can rule out the motor, pump and coupler as well as the lid switch. The only things left (since the timer is activating the motor and causing it to drain) are the clutch and transmission. My guess is your clutch is wore out, in either case, it should go to a qualified repairman.
Posted on Oct 27, 2009
SOURCE: GE WASHER WCXR1070A2WW TUB FILL AND DRAINS NO SPIN,AGGITATE
HUMS WONT START
Posted on Jan 19, 2010
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Mar 30, 2013 | Washing Machines
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Dec 03, 2010 | Washing Machines
WILL WASH BUT IT WILL NOT SPIN AND THE WATER IS SETTING IN THE MACHINE MOD - LXR5432KQ0 SER #CM3226867 TYPE 107
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for a replacement for your washer is 3949247.
NOTE: You DO NOT need to drain the washer to replace the lid switch. Once a defective switch is replaced, the washer will drain.
If you have questions, or need additional assistance, please post back and let me know. I hope this information is helpful.
Mar 18, 2010 | Whirlpool LXR5432KQ Top Load Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Hi, my washer will fill, agitate, stop and not drain or spin.
Hi everyone, I found the solution to my washer problem. I checked the lid switch and it was ok, but the lid lock was damaged. I opened the lock and I solder it and the problem was solved.
I hope this info can help someone.
May 25, 2009 | Frigidaire FWS833A Top Load Washer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Washing Machines Logo
203 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
