I updated my bios, and OS does'nt boot.
I just updated my bios and after that OS does'nt load and it boot over and over.
what will i do now??
  • jphoebe17 Aug 15, 2008
    ok i will try..
    thanks for the concern.
  • 983 Answers
Reinstall the OS .. if you are using XP then you can repair the same installation so that all your files will not have to be deleted ...
you just have to do is insert the XP boot cd and boot it from cd and then you will get an option to repair if you follow the instructions ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
Posted on Aug 15, 2008
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
I need to format my machine ,but i cannot go to the bios setting and cannt boot the OS cd from CD drive,, on which tab can i preess for see the bios setting?
Usually before OS boots you have to press either F2, F5,F9,F12
if neither one works try all F keys until you go to Boot selection or BIOS.
Have fun :)
Aug 17, 2011 | Mercury P4VM800M7 Motherboard
BIOS IS DAMAGE;HOW TO RESET?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart or
http://download.cnet.com/msi-kt4v-bios-windows/3000-2098_4-10162333.html
Update BIOS in your MSI KT4V motherboard for Windows 95/98/Me/NT/2000/XP.
or
Update BIOS in your MSI K7T Turbo2 motherboard for Windows 95/98/Me/NT/2000/XP.
http://download.cnet.com/msi-k7t-turbo2-bios/3000-2098_4-10162343.html
http://download.cnet.com/msi-kt3-ultra2-bios/3000-2098_4-10162341.html
hope this helps
Jul 23, 2011 | MSI NF750-G55 Motherboard
What does it mean when it says NTLDR is missing?
It's me that windows NT loder LDR is missing
if this file (NTLDR) is missing windows can not boot
so you have to make an upgrade or reinstall your operating system
vote please :)
Dec 26, 2010 | Acer Aspire One Netbook
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Computer not booting os
There must be problem with your bios, try upgrading the bios firmware with the new version...You can get the latest update for your bios through the manufacturers website and update it..Once dome , your new harddisk or the old one should be ready....
And try to s\check that the installation of your OS is done through reliable CD, beacuse there is sa chance of virus, which may affect the boot sector leading to no loading from HDD...
To temperorily upgrade your bios, boot from LINUX AUTORUN BOOTABLE cd, which is available free for download and you upgrade your BIOS
RATE THIS SOLUTION
RNJ VINOD KMAR
Aug 05, 2009 | Dell (E210882) Motherboard
In my dell desktop optiplex 330 hard disk is locked by a password and how to Break it.
Is it a BIOS password or a HDD password? If it's sewt in BIOS, you could try to reset the BIOS to factory default (which should remove any BIOS passwords) If however it is a HDD password, it is a bit different.. you may need to restore your sytem (low level, high level formats, then reload your OS sorry but you likely lose all your data..What OS do you use? there are programs that can possibly give you a boot cd depending on whether your system is fat32 or NT.. NT is more complicated because fat32 will not read NT BUT NT will read fat32.. IF you have the ability to restore your OS then first try to do a complete restore with backup.. that way you may be able to save most of your datafiles.. if you have never accessesd the pc then just try a destructive system restore (will low-level, then high-level format the HDD and reinstall your software without any SW passwords..
First thing I would try is to get into the BIOS and unset any passwords there.. If you need more help you can try to contact me mage0213@aol.com with more information
May 04, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Won't Load OS from DVD
If your laptop will post, meaning you can get to the BIOS, then YES. Re-flash it with the original BIOS, or a newer but proper BIOS. Then all should be OK again.
Feb 15, 2009 | Toshiba Satellite M115-S3094 Notebook
Updating bios then the OS does'nt load..
Look like the update to your bios has modified its lookup of IDE / SATA or other hardware.
Windows relies on the details submitted from your bios to run correctly.
Try and re-install windows under repair mode - you will atleast be able to save any important stuff prior to the inevitable.
Aug 15, 2008 | Gateway Tabor 3 (4000532) Motherboard
HDD Booting
check your master /slave jumper settings. have you have moved devices around your cables?  set your boot sequence in the bios. Is there and OS on one of your disks? are they formated?
Oct 24, 2007 | ASUS CUV-NT (CUVNTWOTVWOV) Motherboard
Computers & Internet Logo
David Payne
David Payne
