Question about Keurig B60 Coffee Maker
Coffee maker leaks from the bottom somewhere. Any suggestions?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Posted on Sep 05, 2011
Why does the water I put in the maker run out the bottom
Sounds like it has a leak in the tank or the hose. Unplug the coffee maker and turn it over. See if you can remove the bottom cover. Make sure the coffee maker has not been on and is cool to the touch!
Underneath will be a tube and heating element. Make sure the tube is connected to the water reservoir and that there are no holes or cracks in anything. It could be that someone dropped it and cracked the plastic somewhere.
Oct 02, 2014 | Bella 13600 Coffee Maker, 12 Cup
There seems to be water leaking somewhere. the pucks used to be fairly dry and caked when they were dispenses but now it is wet and oozy. any suggestions?
Is it clean water or dirty coffee water?
If clean then there is a leak on the boiler or one of the water lines.
If dirty coffee water, then remove the brew unit and clean the small chamber under the white plastic valve.
Jan 12, 2010 | Saeco Spidem Villa
Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Nov 21, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Leaking from bottom
The bottom half should bolt to top half. After screws are removed, then you should be able to pull the bottom off and look for cracks, holes, or a bad gasket. You can always use silicone and seal it yourself
Sep 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Hi. My machine leaks from the bottom.Any suggestions as to what this could be?
Remove the brew unit and check the little chamber under the white plastic valve that might be filled with coffee.
Aug 11, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
Apr 12, 2009 | Bunn 10 Cup Home Coffee Brewer
Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Jan 02, 2008 | Guido Bergna Mia Coffee Maker
Keurig B60 Coffee Maker Logo
672 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
