Question about Homelite Garden
I need a gearhead for a homelite z830sb string trimmer. the part # is A04836C. Homelite no longer makes or stocks it. Apparently they don't think their products should last or can last 14 years. Any suggestions on where to find this part?
  • Roy Cagle
    Roy Cagle May 22, 2011
    I am looking for it for you now.
    President:
  • Homelite Master
  • 1,545 Answers
I have seen exactly what you mean. The part is listed as obsolete and has been superceded by another part # UP06970 that is also out of stock NLA (no longer available). But somebody, somewhere on the net has one of these. These guys list it, but it is out of stock...at least it is not listed as no longer available. Your part is the gearhead at the top of this page. You can contact these guys for more information and when it might become available to you if they order you one. I know just how frustrating this is. Anyway, these guys list your part with the new part number.
http://www.cmsmallengines.net/trimmer-parts-c17/homelite-1-2-3-4.html#2
Post back if they can't help you soon and I will keep looking with you!
Posted on May 22, 2011
There is an online vendor that sells the latest version(Homelite/Ryobi part # UPO6970A) for just under $50.00. Here is the link. I hope this helps and good luck.
http://www.ereplacementparts.com/gear-head-p-332843.html
Posted on Jul 20, 2011
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
Where and how do I get a new coil for the Homelite 25 cc engine ?
PartsBuggy.com has lots of replacement Homelite parts, but it's really going to depend on the model you have. You can go to Homelite's website at www.homelite.com and look up the Homelite part # for the part and then use that at PartsBuggy's cross-referencing page to find out if they stock it or not.
Sep 25, 2011 | Homelite Mighty Lite Lawn Trimmer
I don't know how to replace the string in the trimmer..
Please see the instructions for this procedure from your owners manual. Look at page(s) 13. There are written instructions with good diagrams to view.
http://www.homelite.com/system/manuals/stringtrimmers/UT41110_221_eng.pdf
Jul 04, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
I have a Homelite Z830SB Brushcutter. I use it with the blade attached rather than the line, for cutting. It starts fine, but it does not engage (i.e. the shaft does not spin...so there is no rotation in...
the inner shaft could have broken, which is the case a lot when using the blade vs the string remove the shaft from the motor, and spin the inner rod and see if the blade turns, if it does check the end of the rod and see if its damaged in anyway , if the blade doesn't spin, the shaft has broken and will need replacement
Jul 03, 2011 | Homelite Garden
I was given 2 weed eaters, the z830sb, and the d630cd. I need to know what the gas and oil mixtures are for these units.. Thanks Jim
32:1 should be a good mixture for the homelite weed eaters. here is a thread on it, hope it helped Tim:
ttp://forums2.gardenweb.com/forums/load/tools/msg1011591014681.html?13
Apr 24, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
How to remove clutch on model z830sb
The clutch interior must be turned the same direction as the engine to loosen (reverse threads), tapping with a screwdriver and hammer usually does the trick. When you install the new clutch make sure you apply an anti seizing compound to the threads.
May 26, 2009 | Homelite Garden
Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Garden Logo
271 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
