Question about Hampton Bay 24002 Ceiling Fan
UC7078T Remote So, I have the remote that no longer works. We have switched batteries, verified dip switches & codes in both the remote and the receiver. We do not have a user manual, as this fan came w/ the house. Our problem is that the fan is stuck on REVERSE and it's 110 degrees here. We'd like to know if there's a way to reverse the fan via wiring. This fan is remote only & DOES NOT have a reverse switch on the fan itself. I would replace the remote & transmitter, but Hampton Bay no longer sells them. CONVENIENT. Thanks for your help!
  • marycm Sep 28, 2008
    Yup, same thing happening here. It used to work fine, now all of the sudden nothing. The light works (it is connected to the main lights in the room) but nothing comes from the remote control (the little light lights up when you press a button but nothing happens). There is no way to turn the fan on on the fan itself. We tried replacing the battery, nothing.
Try opening remote control
vary (4) "dip" switch(s) positions
when I opened mine-all four were up
I moved the 2nd switch down and it worked!
Posted on Oct 26, 2008
    New Friend:
  • 4 Answers
There is a reversing switch on top of the light canopy that is located along the inner rim of the upper light assembly.
Posted on Dec 07, 2009
  • 3 Answers
Take apart the remote and heat up the solder connections, I did that and it fixed it.
Posted on May 26, 2009
SOURCE:
Hampton bay uc7078T remote with uc7083T receiver ?
read your instruction manual download from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 29, 2012 | Universal Remote Control Hampton Bay...
Remote will not operate fan or light. Replaced battery. Remote light glows red when pressed
Check dip switches in remote and dip switches on receiver in the canopy of the fan, make sure the settings match exactly. Make sure there is power to the fan. Make sure the fan and light are not manually set to off by pullchains that may be on the fan. If the fan does have pullchains, wire it directly in (bypass the remote in the canopy) and test the functions to make sure the fan and light are working. If it works without the remote, but not with the remote, and the dip switches are set the same and you have new batteries, then the remote and receiver should be replaced.
Feb 28, 2011 | Hunter 52" Ceiling Fan With Light And...
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Power went out and now ceiling fan won't work
Before you try all of that try the on/off switch, I tried holding down the light switch on the remote and turning the on/off back and forth several times and then the light came on... it is very tricky, but I knew my battery was good, and the fan worked before the power went out and the dip switches did not need reset or changed. I tried many different combinations so I am not sure what tripped it up, but try that before changing anything or pulling the fan cover off. Best of Luck
Sep 07, 2009 | Hampton Bay Dryers
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay remote (023617) turns on wrong fan
Program it to match the receiver's programming in the fan body:
In both the remote (transmitter) and receiver in the fan is a small (about half inch square) DIP switch (Dual In-line Package switch) that has four small sliding switches on it. The pattern of the switch positions must be the same on the transmitter's switch as the receiver's switch for the remote to work (it puts them on the same frequency). There should be an instruction booklet that comes with the remote telling you where exactly the transmit and receive DIP switches are
Apr 19, 2009 | Hampton Bay 13087 70450 Carousel II...
Two ceiling fans, both remotes control the same fan
Most likely the dip switches on the remote receivers don't match (on the second fan, the one that doesn't work). While the remote dip swithes on both remotes match the working fan. You can simply reset the dip switches on the second fan receiver to match the one working remote, i.e. you don't need to have a second remote, one can work both fans as long as the codes (dip switches match). If you want you can make all the remotes the same, that way you have two remotes, or if you want them independent each remote and remote receiver must have unique codes (dip switch settings).
Nov 30, 2008 | Universal Remote Control Hampton Bay...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hunter Remote Control # 27185
Do not use the factory default position in either fan. Double check the dip switches, and make sure they are the same for each individual receiver and remote.Different codes for each. Dip switches are the oppsite direction in the remote for some reason?
Jan 01, 2008 | Hunter 27185 Remote Control
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Hampton Bay 24002 Ceiling Fan Logo
3,871 people viewed this question
Top Hampton Bay Dryers Experts
Ronald Buckner
Level 1 Expert
Donald Klecher
Donald Klecher
Level 1 Expert
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
