Question about Polaris Pb4 - 60 Booster Pump
The male and female wires that feed the pump power have burned out. Where can I find replacement wires and what is approiximate cost
  • 10,865 Answers
Hello wk.... I recommend that you go to a polaris dealer who will either have these exact wires in stock or be able to order them for you. That way you will have the correct gauge, color, and end connectors to allow for a quick and simple installation. The cost should be about $5. per wire. Joe
Posted on May 22, 2011
How to care for siamese fighting fish when breeding
This is the PC Desktop Problem page you should post problems in the appropriate section
However
Siamese fighters, also known as Siamese fighting fish or bettas, are colorful freshwater fish with long, flowing fins. They are known as hardy fish, and are relatively easy to care for. These fish can be aggressive, and two males kept in the same aquarium will often fight each other, hence their name. Because of this aggression, breeding bettas can sometimes be a bit tricky. Care must be taken to ensure that the female betta is not injured. However, when the proper steps are taken, breeding Siamese fighters can be a success.
Set up a breeding aquarium. This aquarium should be small, only 10 gallons, and should have only about 6 inches of fresh water in it. Place tall plants in the aquarium. These plants will provide a place for the male to anchor his bubble nest. This nest is where the eggs will be kept once their laid. You can also provide an artificial anchor, such as half a styrofoam cup, if you feel it's necessary. Place a thermometer in the breeding aquarium and monitor the temperature of the water. When breeding, Siamese fighters prefer a temperature that hovers right around 80 degrees Fahrenheit. Place a divider in one side of the aquarium. This can be a regular aquarium divider, or a glass chimney. The divider will protect the female from the male until their ready to breed. However, the divider should let the male see the female, so that he will begin preparing to breed. Find a healthy pair of bettas. Male bettas usually have longer fins that the female fish. Males also tend to be more colorful than the female bettas, which can appear somewhat washed out. Place the male in the largest part of the aquarium. Place the female behind the divider. Condition the fish, preparing them to breed. Do this by feeding both the male and female fish live or frozen, then thawed, meaty foods, such as brine shrimp or bloodworms. Observe the fish. When the male is ready to breed, he will begin to construct a bubble nest. This nest will be clearly visible at the top of the aquarium, and will be several layers deep when it's finished. When the female is ready to breed, she will display dark bars along her sides. A white breeding tube will also show under her pelvic fin. Release the female into the main part of the aquarium, with the male. The male will chase the female around, and may bite or nip, in order to entice the female under the bubble nest. The male will then wrap around the female, squeezing until the female releases the eggs. Remove the female as soon as the spawning is over, or the male may kill her. The male will continue caring for the eggs, and later, for the young fish, until they are free swimming.
Facts Sheet: How to breed siamise fighting fish
http://aqualandpetsplus.com/Betta, Breeding basics.htm More information on Siamese Fighting Fish http://animal-world.com/encyclo/fresh/anabantoids/bettas.php
Apr 13, 2013 | Computers & Internet
A CH pressure sprayer PW175000AV Ser# 00842 was electrically taken apart without noting how wires were to be reattached. There are 4 male spade connectors on rocker switch which works fine. Power has...
Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
May 05, 2011 | Campbell Hausfeld PW1750 Electric Pressure...
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
Everything is unplugged, I just need a wiring schematic to plug everything back in
Does the motherboard have a "purple" socket?
Does your keyboard have a "purple" end?
If so, join the male to the female,
rotating the male until the stiff pins line-up with the holes.
Does the motherboard have a "green" socket?
Does your mouse have a "green" end?
If so, join the male to the female.
The end on the monitor's video-cable has 3 rows of pins;
there's only one place on the computer with 3 rows of holes.
Notice that the sides of the male are tapered,
so that it only fits ONE way into the female.
Similarly, the female end on the power-cord is tapered,
so that it only fits ONE way into the back of the computer.
Note where it connects -- there may be a "rocker" switch,
with a '1' and a '0' on the ends of the rocker.
Press the '0' end down before you reconnect everything.
Press the '1' end down after everything has been reconnected.
Do your PC speakers have a green tip?
If so, then connect the male from the speakers to the green female socket.
Sep 14, 2009 | 3Com Computers & Internet
Power head does not activate
have you pushed the rest switch on the top housing? It may be on the side?
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Orange wire-Female connector.Brown wire -male
orange is the output (trigger), and brown is ground
Jun 30, 2009 | 1986 Yamaha RD 350
I have a pair of JBL Platinum Series computer speakers that came with a Compaq Presario Desktop. I've since purchased a Dell Dimension 9200 Desktop and want to use the JBL speakers with it, but the power...
Go to the family dollar they have those wires that have both male ends. It is meant for ipods, and mp3 players so you can connect them to modern stereos that have inputs like that. I bought sevel of them because they are very usefull for about a few bucks each.
Apr 15, 2009 | Belkin COMPONENTS Computer AC Power...
Washer front loader
Does your model have a Male Female latch, where the femal receptor of the male plug is plastic?
Regards,
Worldvet
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Polaris Pb4 - 60 Booster Pump Logo
64 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
