Question about Pool & Spa
My Teledyne Laars EPG-175 pool heater has a pilot light, but will not ignite. My limit switches are closed, as is my pressure switch. Temp sensor bulb, or pilot generator? I do not get a flashing red LED on my temp control board indicating milivolts present. My pot switch is working properly also.
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
  • 139 Answers
SOURCE: I need an install manual for teledyne larrs one
try jandy pool products on internet.most manuals are available
Posted on Aug 20, 2009
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
  • 990 Answers
SOURCE: I HAve old Teledyne Laars pool heater. When I try
The aluminium has gotten old in the pilot tube and is starting to leak. You can just replace the tube but when you start disturbing the pilot it can lead to other problems. I would sugest getting a whole new pilot assembly and replaceing the whole thing.If it that old be sure to ask for propane or natural gas when you order the part.
I don't know about old books online but you can write to Laars and ask them. They are under Jandy-Laars now.
Posted on Jun 27, 2010
Laars Pool Heater, pressure valve or something else,
bad pressure switch or incorrectly set should have no continuity when off it should when running put on 2000 for ohms should have 500 millivolts when off then turn on and it will start counting down at about 200 should light make sure all connections are good and all safety circuit is good
Jun 24, 2015 | Teledyne Laars Laars Lite 2 Pool Heater...
My pilot light is lit but the heater won't turn on.
GET A NEW PRESSURE SWITCH.. CALL AND ASK FOR A PRESSURE SWITCH FOR SAY A HAYWARD POOL HEATER .. LOOKS LIKE THIS ..EBAY Pressure Switch Hayward generic pool heaters also H100
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I replaced the ignition transformer in my Teledyne Laars epc325 pool heater and cleaned everything. When I switch the heater on the burners all work fine but they only cycle on for about 10 seconds then...
This is probally your ignition wire is bad and not reading flame at the pilot or your pilot is bent or something so that when the pilot lights the flame isn't hitting the sensor probe at the pilot. When looking under the heater use a mirror so if you get roll out of the flame you don't get burned. Good luck and be careful.
Feb 26, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will stay on but burners will not ignite, checked all switches seem to be working allright, still no burner ignition
Possibly a flow switch not closed, or a limit switch open. May even be the pilot generator not producing enough mili-volts to operate the gas valve. Safest way is to have it serviced by a heating contractor. You dont have to call a pool company unless you wish.
Aug 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light wont stay lit
If this is a new item then you will need to let the gas run alittle bit longer. If this is a used item then it sounds like you are going to need to replace the flame sensor. You may have to even do it on the new item. But usually for the first start you willl need to hold the pilot down for about 1 minute to really let things heat up in there then when you release all will work
May 21, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Pool & Spa Logo
161 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
