Question about Schwinn Cycling
I have two protanium batteries for my Campus Electric bike. Neither of them will charge. BP-L2410EH2 and BP-L2410EB are the numbers on the back of the batteries. I bought my bike from a bike shop in Chicago one year ago. Suggestions?
    New Friend:
You can get those rebuilt by EBike Marketplace:
https://ebikemarketplace.com/blogs/news/schwinn-tailwind-e-bike-battery-replacement
Posted on Aug 25, 2017
Sell me your batteries and charger. Danielmonteshernandez@gmail.com
I need power for my ground penetrating radar unit. These batteries might work.
Daniel Montes
469-563-8998cell
Posted on Aug 22, 2011
Well, I think the answer is in the question...
Either the charger is bad, or the batteries are. Have someone qualified check the charger voltage.
Replace whichever is bad.
Posted on Jun 11, 2011
Can I dissasemble a BP-210N battery pack and refill it?
You could do this absolutely, however with the cost of the batteries needed and the knowledge needed to safely solder to batteries terminals it is more cost effective and safer to purchase from Ebay.
$16.99 coming out of Gardena, Ca with free shipping BATTERY FOR ICOM BP 210 BP 222 BP 210N BP 209N BP 222N
Oct 02, 2015 | Radio Communications
What bike company uses USF as first 3 digits in
Borrow Our Bikes - USF Campus Recreation
usfweb2.usf.edu/CampusRec/Outdoor/borrow.asp
A bike checkout includes either a cruiser bike, mountain bike, or hybrid bike, along withbike lights, a helmet, lock, and key. Checkout is free for current USF ...
Sep 24, 2014 | Cycling
After I charge my battery on my Xtreme Scooter XB-700li (I remove the battery and charge it inside the house) when I place the battery back in the bike, no power. The bike worked the day before; now...
Did you check if there is still enough fluid in the battery chambers?
Don't trow in normal water, because the battery will not appreciate. Just demineralised water will do.
Jun 24, 2014 | X Treme Scooters X-treme Xb-700li Lithium...
I have a sakura electric bike and when I use the throttle the battery charge indicator drops to empty and it cuts out, however when I stop the charge indicator rises again. Any suggestions.
Sounds like your batteries are low in capacity and need replacing. The battery indicator is measuring voltage. As you draw power from the battery the voltage is dropping (sagging) because the batteries are weak/old. When you stop drawing power the voltage rises again.
Aug 12, 2012 | Electric Bicycle Motor, Bike,electric...
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
Feb 27, 2011 | Electric Bicycle Motor, Bike,electric...
I'm nokia E63 user. Battary of this phone ( BP-4L) does not give back up for a day after full charging. Today when i got up in morning i touched my phone and found it overheated. I brought this phone in...
you should replace your battery
or
take the battery out and leave it out for an hour atleast, give your phone and battery little rest then use again.
remember never ever over recharge your battery. two hours are more than enough. and always swtich your phone off when you are charging it.
Nov 10, 2010 | Nokia BP-4L Battery
Not charging video will not eject
CANON MV630I battery Specs:
  • Cell Type : LI-ION
  • Volts : 7.4V(Compatible with 7.2V)
  • Capacity : 4400mAh
  • Average Run Time :2-4 hours(minimum)
  • Color : GREY
  • Dimension : 55.10x38.20x39.90mm
  • Net Weight : 146.00g
  • Cpmpatible Model:
  • canon 5797a007, canon 5797a010, canon bp-508, canon bp-511, canon bp-511a, canon bp-514, canon bp-522, canon bp-535, canon pc511, canon vcn009, canon vcn009s, cta db-bp522, delkin dd/bp522, duracell drc522, empire bli-193-2.4, energizer er-c600, gp vcl008, hahnel hl-522, hama 46810, hama cp-810, optex li36, polaroid pr-522l, rayovac rv5462, sakar bp-522cl, sunpak hl-522s, techcell l522us, vivanco bp-22672decf09.jpg
    Jul 22, 2010 | Canon MV630i Mini DV Digital Camcorder
    I have an electric scooter/bike from http://www.giobikes.com/Electric-Scooters-in-Canada/ When I received it, nothing worked on it accept the alarm system. The battery wasn't charging, and I was told...
    Dear Citiboyblu,
    Yes.... if the battery has gone flat and then charged with the positive and negative leads reversed, it will adopt a reverse charge.
    There's a theory that if you flatten a lead/acid battery then reverse charge it then flatten it again and charge it correctly. Some of the lead sulphate that contaminates the plates will be dissolved back into sulphuric acid and increase the performance/lifetime of the battery.
    Never tried, so don't know if the theory works.
    You can also visit to the following link for more explanation.....
    http://mgaguru.com/mgtech/electric/et202.htm
    May 13, 2010 | Electric Bicycle Motor, Bike,electric...
    Cycling Logo
    1,343 people viewed this question
    Top Schwinn Cycling Experts
    Michial Gueffroy
    michael
    michael
    Jim Goldsmith
    Jim Goldsmith
    Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
