The oil drain for the engine oil is a hose that comes off the lower backside of the oil tank on the right side of the bike. It goes down behind the transmission and comes out on the frame down low on the swingarm about where the rear end of the shocks connect. It has a plug in the end of the hose. On some of the later models, this hose connects to a crossmember on the frame with the plug directly on the underside of the hose where it connects. The transmission oil drain is a small pipe plug, 1/8" pipe plug, on the end of the transmission just below the chrome release mechanism housing behind the exhaust system. It takes a Torx key to remove the plug. The transmission holds 20-24 ounces of H-D Syn3 20W50 synthetic engine oil.
Good Luck
Steve
Hey thanks..I have another ?
