Question about Leeds 805058 High Sierra Tahoe InOutdoor Weather Station Graphite
No longer shows temp (indoor or out) or weather. Outside unit is still working and showing temp.
Mine did the same thing. I just had to replace the batteries in the main unit and it is working again. Good luck!
Posted on Jan 14, 2012
  • app_3rp12804
    app_3rp12804 Jan 14, 2012
    I forgot to mention that I pushed the Resynch button, and then the Wave button afterwards....
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
Replacement has to be done in a certain order.
  • Remove all batteries
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Dec 13, 2016 | Measuring Tools & Sensors
Out do I get the outside temp back.
You have to remove all batteries, both outdoor and indoor. Install replacement batteries in the outdoor unit. Back indoors, install replacement batteries in the indoor unit and wait for temperature to be displayed. If nothing happens, the outdoor unit may have failed.
Jun 17, 2016 | Measuring Tools & Sensors
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Remove batteries from both units
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
I cannot get the outside temperature to show on the inside monitor
Try the usual fix by removing batteries and reinstalling/replacing batteries starting with the outside unit. Wait for as long as 10 minutes for the ouside temperature to be displayed on the indoor unit. If nothing happens after 10 minutes, the outside unit may have failed.
Oct 20, 2013 | Oregon Scientific Bar806hga Helios Solar...
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
Cannot get the outside temp to respond on a WS9047U-IT
Bring the outdoor sensor indoors. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the outdoor sensor. Put the batteries back in the main unit. DO NOT PRESS ANY BUTTONS. Wait 10 minutes or until the outdoor temperature shows. Once the temperature shows you may use the buttons to set the clock, etc. If it does not show after 10 minutes, then try again.
Jan 07, 2011 | La Crosse Measuring Tools & Sensors
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Leeds 805058 High Sierra Tahoe InOutdoor Weather Station Graphite Logo
405 people viewed this question
Top Leeds Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Leeds Measuring Tool and Sensor Expert? Answer questions, earn points and help others
