Question about Emerson LC320EM8 32 in. LCD TV
Trying to hook PS3 up to tv but it keeps saying change computer screen resolution and I have it hooked up in the HDMI slot 1 and I tried 2 but I get the same. I go into the PC menu but it will not let me adjust anything. Is there a solution to this?
  • 53 Answers
Try unplugging both the tv and the ps3 then plug them both in turning the tv on first then turning the ps3 on by holding down the power button for about ten seconds until it beeps. then it should work.
Posted on May 23, 2011
  • Myshia Robertson Jul 27, 2012
    can i do this my 32" emerson because its not picking up on home and it sometimes pick on retail?
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Computer hooked to TV through stereo
a computer is a versatile gadget its meant to format anything thats comes to its screen this is done by sophisticated drivers that will say 'think ' and place anything in a smart manner this is the way its made so u cant do anything about it unless u have a full screen option, hit full screen to enlarge your picture
Jul 08, 2013 | Mitsubishi WD-65738 DLP TV
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I am trying to hook up my ps3 but it says change resolution source
make sure everything is plugged in correctly. also make sure that the input/source of your tv is correct. If all these don't work, then: 1. unplug both the tv and the ps3 2. plug them both back in 3. turn the tv on first make sure it is on the right hdmi source. 4. turn the ps3 on by holding down the power button for about 10 seconds until it beeps.
the ps3 start screen should show up now.
May 28, 2011 | Philips 32PFL3505D 32 in LCD TV
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Trying to hook up HDMI to PS3 and the TV keeps saying not a supported format
Try using another AV cable (like a normal composite cable) and try going through your PS3 setup. It may be that it is trying to go to 1080p or something because it is the HDMI, which wouldn't work on yours I bet. See if you can disable the higher resolutions and try the HDMI again to see if you can get the 720p to work. Hope this helps!
Oct 21, 2009 | Sylvania LC195SL9 19 in. LCD TV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
I have a 50 in vizio plasma. just hooked up a psp3 for the blue ray, but the input only says 480. What gives? shouldn't this be 1080? I can't find an ajustment on the menu screen on my tv?
What you need to do is hook up your PS3 to a different tv. Then in Display setting on the PS3 change it to 480p. Hook it up to your vizio and while on the ps3, change it back to 1080p. Most Vizios don't have a Progressive scan that adjusts to the output settings of the PS3 (or other device) .
Apr 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Emerson LC320EM8 32 in. LCD TV Logo
323 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
