Question about Sta Rite Sta - Rite 1/2hp Dura - Glas Inground Pool Pump
Our pool/spa pump will cut off for approx. 20 minutes several times during an 8 hr cycle. It never use to do this. The pump is around 3 1/2 yrs. old.
  • 35 Answers
If the motor is very hot it could be shutting off due to a thermal safety device.
Anything that makes the motor work too hard and/or heat up will trigger this.
Blockage in the water lines
Clogged pool filter
Worn motor bearings
Lack of air flow around the motor
Weak or damaged motor windings.
A defective thermal limit switch will **** off the pump when the pump is within heat and load limits.
Posted on May 22, 2011
On leisurerite spa pool what does code 1-3 mean
If your system is equipped with a circ pump, it may be configured to work in one of three different ways: 1)
The circ pump operates continuously (24 hours) with the exception of turning off for 30 minutes at a time
when the water temperature reaches 3°F (1.5°C) above the set temperature (most likely to happen in very
hot climates). 2) The circ pump stays on continuously, regardless of water temperature. 3) The circ pump
will come on when the system is checking temperature (polling), during filter cycles, during freeze
conditions, or when the blower or another pump is on.
Dec 06, 2016 | Pool & Spa
Hi there I have a spaform oslo.The problem I got is that the filtration sequence is running all the time the jets are constantly on speed 1. The Tub is up to temp I have no fault codes. Thanks Justin
make sure correct time is set on unit, then double check to see if filter cycles were ever change, follow manul instructions attached.
Filter Cycles
On all systems, the pump and the ozone generator will run during
filtration. At the start of each filter cycle, the blower [if
fitted] will run for 30 seconds to
clean out the air channels. Pump 2 and pump 3 [if fitted] will run for 5 minutes.
There are two filter cycles per day. The start/finish times of
each cycle are programmable. To program, follow the steps under
the heading
How to set the
time & filter cycles
on page 9, ensuring that you press
"Mode/Prog" to advance to the next setting option.
The factory default filter cycles are as follows:
The first filter cycle is automatically activated at
8:00AM and operates the pump until 10:00AM. The '
F1'
indicator icon on the control touchpad will be lit
when filter cycle 1 is running.
The second filter cycle is automatically activated at 8:00 PM
(20:00) and operates the pump until 10:00 PM (22:00). The
'F2'
indicator icon will light when
filter cycle 2 is running.
http://thecoverguy.co.uk/wp-content/uploads/2015/05/Spaform_Owners_Manual.pdf
Jan 07, 2016 | Pool & Spa
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
May 11, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Hayward Swimpro Sand filter shuts off after approx 2 minutes
It sounds like the pump is either overheating or the thermal protection switch that senses the overheating situation is defective. If nothing else changed like running on an extension cord, etc, a small motor repair shop can get you back up and running fairly inexpensively.
May 23, 2009 | Hayward SAND FILTER, PRO SERIES
I have a ultima pool pump on my pool that is one year old. The presure is low? We have checked all baskets and hoses all seem to be fine. Any ideas? THANKS
Are you sure this is a problem??
I always backwash when the pressure gets above 20. After a good 3 -4 minute backwash and rinse it runs around 17.86 or 18.
Now, I am talking about a pool.... in a spa I'd guess that the pressures would be lower than 17.86
May 13, 2009 | Pool & Spa
Sta Rite Sta - Rite 1/2hp Dura - Glas Inground Pool Pump Logo
269 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
