Question about Dual XDVD8181 Car Video Player
Xdvd710 if you have it hooked to the parking brake do these codes they are talking about work
  • 1,586 Answers
No - there aren't any codes to unlock the playback without the e-brake.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 25, 2008
Try to bypass a emergeny brake pedal switch for a touch sceen dvd player radio. Its a dual model xdvd710
TRY GROUNDING THE WIRE THAT HAS TO BE HOOK TO THE E BRAKE YOU MAY EVEN HAVE TO GET A SWITCH AN ON AND SWITCH THAT MIGHT WORK EVERY DECK IS NOT THE SAME
Feb 19, 2011 | Dual Electronics XDVD710 Car DVD Player
Emergency brake warning will not go away even when the emergency brake is on.
what emergency brake are you referring to? Is it a car emergency brake and which car model are you talking about?
Please rephrase your question, because I don't really understand it.
I look forward to your reply.
Bye for now.
Jul 01, 2010 | Dual Electronics XDVD710 Car DVD Player
How do i hook up my parking brake wire on my xdvd710
The yellow/blue wire out the back of the head unit needs to be hooked up to the same wire that is responsible for illuminating the "BRAKE" light on your dash. This tells the DVD player that the car is not in motion. Where this wire is and how to tap into it is entirely dependent on what kind of car you have. You may need to trace the wire out or consult a wiring diagram.
If you wish to bypass this feature (which may be illegal in some states) try this:
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
Feb 26, 2010 | Dual Car Audio & Video
How to bypass a dual xdvd710 without the remote
ground the brake wire from the radio to a switch that cut off and on, to the chassis ground you will have to hit the switch every time you want to watch the tv the switch acts like its hook up to the parking brake so when u hit it twice it thinks that the brake is engage
Oct 09, 2009 | Dual XDVD8170 Car DVD Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 31, 2008 | Dual XDVD8181 Car Video Player
Dual xdvd710 wire code
http://www.yotatech.com/~corey/tech/slc_stereo/16.jpg
its a sony diagram but the codes are the same, now you should have an extra solo green i belive may be a diffrent color that is supposto go to the parking switch, just hook this up to a ground
Jul 25, 2008 | Car Audio & Video
Dual XDVD710
Is there an over ride code that will allow the dvds to play while the vehicle is running? I am in a custom car club and we have many vehicles with Dual in dash dvd players in them... If there is any way you could let me know either way, that would be great....
Mar 23, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
all you have to do for you to be able to play video while driving is... take the yellow wire with blue strip and wrap it with your ground wire and connect the ground wire to a GOOD chasie ground
Sep 13, 2007 | Dual XDVD8181 Car Video Player
Blue screen will not go away
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
Mar 03, 2007 | Dual Bravo HRC-0703 DVD Package Mobile...
Dual XDVD8181 Car Video Player Logo
117 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
