Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Loose handle on freezer door model mfi2568aeb
  • 125 Answers
SOURCE: Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Posted on Jan 08, 2008
aborcass
  • 2651 Answers
SOURCE: Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Posted on Mar 12, 2008
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Posted on Jun 24, 2008
aborcass
  • 2651 Answers
SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Posted on Feb 13, 2009
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
How to fix loose freezer handle on whirlpool refrigerator
This repair is not as easy as you might expect. The door gasket, inner door panel, and insulation must be removed to get at the screws attaching the door handle.
Oct 05, 2014 | Whirlpool Refrigerators
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
Freezer door handle is loose
Usually those handles push directly up to come off the pegs. You really have to "lean in" to push the handle against the door and then try to slide it up. Once you get it off, you can tighten the studs (or whatever hook/clip thingy they came up with) and slide it back on.
Feb 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Need program code for the refrigerator there is
Look under the toe plate for the tech sheet. If it is missing the part number is 16026830
eric
Jun 30, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
Loose freezer door handle on my whirlpool side-by-side refrigerat
you should be able to pull straight up on the handle (with force) and it will come loose from the retaining screw. usually its just the retaining clip that comes loose from the door but sometimes you will have to replace the entire handle to repair the unit. if your not having any luck getting it off message me with a complete model number for your refrigerator and i will see if i can get you a little  more detailed information. thx peyton
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
230 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
