Question about Garden
I'm working on a echo gt-200 weed wacker and can't get it to start. I have compression, fuel and spark. what can I check
  • 35 Answers
Use only FRESH gas. 2 cycle motors are sensitive and will not run on gas that will still power a lawn mower.
I fought with this for years before realizing how gas degrades over time - especially in plastic gas cans - as the important fuel molecules can evaporate right through the plastic.
Use a quality 2 cycle oil and mix to proper ratio for the saw.
Posted on May 22, 2011
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
I can't prime my carburator on my Echo GT200r weed wacker?
clean your fuel filter and then clean your carb and replace diaphram and needle and make sure hoses are good while you are at it, the methanol causes needle and diaphram to get stiff and gum up not letting fuel into carb when primed, replace your primer blb while at it
Sep 17, 2011 | ECHO, Inc. PB-251C Handheld Blower
Have a toro 51940 model gas weed wacker that just won't start. What's the most common reasons? I replaced the spark plug already!
Check and clean the air filter. That's always been my problem. Wash/dry add a drop or two of oil and work it in.
May 07, 2011 | Garden
My craftsman 32cc weed wacker (model#358.791071) dose not start.
Many things to check. Spark, fuel and compression. Check these to narrow it down.
Nov 27, 2010 | Craftsman 25cc Gas Line Trimmer
Weed wacker wont start
Try a new spark plug or checka and see if it is getting fuel
Jul 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Ball will not prime
you can check the filter in the tank just blow the filter out if that don't work check the lines going to the bulb if you have change the bulb out change the lines around
Jun 27, 2009 | Echo Rapid Loader, Trimmer Head
Weed wacker
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Oct 31, 2008 | Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
