Question about Mtd Garden
How to operate sears5 hp rototiller. Especially the gear shift. Has reverse
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Find the long model number on your tiller. Then go to this site: http://www.managemylife.com/mmh/owner_manuals
Enter your model number and searh for you manual. When the manual is found click get manual or rt click the manual you want Owner, Engine, or parts and download it. The instructions will be in the manual.
This is an example of a model number: 917295852 and the manual for that rear tine tiller is here:
http://www.managemylife.com/mmh/owner_manuals/86874/CRAFTSMAN-Rear-Tine-Gas-Tiller-1006404L?brand_name_search=917295852
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
My craftsman rototiller shifts really hard
Check the oil in the transmission.
Consider getting a service manual for your tiller.
www.searspartsdirect.com/partsdirect/brands/Craftsman-Parts
Jul 01, 2014 | Craftsman Garden
I have a 98 BMW 328i with a manual 5-speed transmission. One day I get in the car and noticed it was hard to shift into gears the clutch felt good and car would drive normal just stiff to put into gears...
It could be typically due to one or two things:
1) The clutch plate is sticking on the gearbox splines due to build up of corrosion or lack of lubrication. May happen especially after long standing with no operation.
2) Gearbox oil is old and requires replacement.
3) Clutch operation requires adjustment or repair. Check clutch fluid or cable condition and operation.
Nov 17, 2012 | Cars & Trucks
My gears grind when shifting, especially reverse... HELP PLEASE!
clutch could be worn out ?
how many miles since it was replaced ?
Jun 28, 2012 | 1988 Toyota Pickup
Craftsman rototiller mod. # 917-294260 won't go into gear
try rolling it a bit. Sometimes the gear doesn't fully mesh correctly. As you try to shift push or pull the tiller juuuust a bit back and forth and try to shift as you do that see what happens. Or go into neutral and rock it then try again.
May 05, 2010 | Craftsman 8.50 Torque Rating Dual...
Car shifts hard (up & down), especially shifting to reverse.
that delayed reaction may be the transmission slipping. with those many miles it could be the transmission going bad
Feb 21, 2010 | 1992 Honda Accord
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
1990 dodge varavan will not go into reverse
It is more then likely either a solenoid or a clutch pack. If you hear a bump and then nothing when you shift, it is probably the clutch pack, if nothing happens, it is more then likely the solenoid. The bad news, it will require a rebuild either way. Reverse gears are some of the hardest to change, and especially on that transmission, it will be quite a process to repair.
Jul 12, 2009 | Mitsubishi Minivan Cars & Trucks
Gear shift won't move out of park sometimes
look for transmission shift interlock solenoid fuse.or a bad brake switch will cause transmission not to come out of park.
Mar 16, 2009 | 1999 Pontiac Firebird
Mercedes C-203 automatic transmission does not
At sounds like a problem with the E.P.S Hve you checked to see if the Air pipes feeding the unit arn't broken or caught. Might even be a broken selector fork in side the box. the old 1825 merc 6x4's Had a similar fault especially the ones on D and E reg
Mar 10, 2009 | Mercedes-Benz Mercedes Bentz Actros Semi...
Garden Logo
149 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
