Question about Canon BubbleJet i9950 InkJet Photo Printer
I9950 canon photo 5 orange flashes 1 green, incompatible cartridge installed. replaced cartridges with originals - no change. reset printer - no change un-plugged it over night - no change been told it's un-repairable?? help greatly received. Grahame
  • 1019 Answers
SOURCE: incompatible print cartridges?
just click on them to say ok, and accept the unsupported cartridges ( if applicable ) do you get the choice.
certain printers, have an option in printer prefs, to change cartridges. check the cartridges are the same ( or compatable )
if the cartridges have a chip fitted, they need to be reset if recently filled.
hope this helps mike @ Compurepair.
Posted on Feb 20, 2008
SOURCE: Canon i9950
Five flashes: Print head not installed / Print head not installed correctly / Defective print head
Install the print head. If the print head is already installed, remove the print head and check the electrical contacts for foreign matter, then reinstall.
For the i9950 ONLY: When the CD-R tray is set in the printer, remove the CD-R tray and set the paper output tray to the paper print position, then install the print head.
After reinstalling the print head, you may need to realign it.
If this error still remains, the print head may be damaged
Posted on Jun 23, 2008
SOURCE: CANON IP 1880
Hello, My printer showing 5202 service error before that "printer is busy" mssege shows and stop the printer. if top is open and close then printer started printing after two line printing repeat the error.
Posted on Sep 30, 2008
i need install canon ip1880.. how?
Posted on Oct 05, 2008
  • 48 Answers
SOURCE: Canon i9950
Yes, the flashing light on start-up is actually the Waste Ink pad is full
a Canon tech suggests that the job is very difficult (unfortunately even for them)
HOWEVER....
good news is that you can override it for awhile...
  • turn off power
  • press & hold RESUME button, then press POWER button
  • continue to hold POWER then release RESUME button
  • Press RESUME Button 2x quick
  • Release both RESUME and POWER
  • Green light will now blink, then stop
  • With Green light on....press RESUME 4x
  • Push Power button to turn printer off
this should resolve the issue
remember to rate the solutions...anything less than FIXYA actually lowers my rank...I didn't make the system...just wanting everyone to understand the impact of their vote....so if you need further help...just ask....hope it fixya'd...if it did then rate please!
bearb
Posted on Nov 15, 2008
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
7 orange flashes and then one green..what does that mean?
7 orange flashes of the alarm lamp means that FINE cartridge is not installed in the correct position. Confirm that the FINE Cartridges are installed in the appropriate positions.
Please refer to the link below to see document on replacing FINE cartridge http://support-ph.canon-asia.com/contents/PH/EN/8200182600.html
The link below gives you information regarding Causes and Solutions when Alarm Lamp Flashes Orange http://support-ph.canon-asia.com/contents/PH/EN/8200187300.html#5
Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Mp160
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
    1. try to take out colour ink and then put in again to see ok or no
    2.try to install new cartridge to see ok or no
    3.try cleaning head just go to printer preferences go to find services and click clean head.
    4.if this all can't is better you send you printer to authorized canon to check you printer is print head problem or no....
    Error E5 means a problem with cartridge chipset, here follows reset procedure, it does not always work:
    Error E5 is a problem with cartridge ink counter. This happens when you use refilled or not original crtridges.
    Try removing cartridges and putting them back in place.
    Here is the whole service procedure for Pixma, you must use this to reset the ink counter:
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
    the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
    service mode. (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
    function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
    orange and green, starting with orange.)
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset See waste ink counter reset
    procedures below.
    5 times Orange Destination setting See Destination setting
    procedures below.
    6 times Green Print head deep cleaning
    11 times Orange Button / LCD checking
    12 or more times Returns to a menu selection
    If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement
    Sep 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Why flash by 5 times the orange led?
    Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Good Luck, I hope this helps?!
    Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
    5 orange light flashes and 1 green light flashes ???
    Hi There, 5 orange light flashes and 1 green light means that the printer is not recognising the cartridege. Iam having the same problem with mine and Iam currently trying to find out why. I have installed the correct cartridge so I'm not sure why it isn't recognising it. but once i know i will let you know
    Jun 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    Canon PIXMAR MP150 E5 problem
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    toi-i-28
    Apr 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Canon PIXMA MP160 E5 error.
    The unplugging procedure is called hard reset, and is useful only when there is no real problem on the printer.
    button pressing
    procedures below.
    procedures below.
    If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement.
    Aug 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    CANON IP 1880
    Mar 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    MP150 Error code 4 and 5
    Don't use refill cartridges, because it will damage your printer someday. and will cost your parts as brand new. so better use the original ink.
    TRY THIS STEPS...
    Mp150 Reset Counter
    Service mode operation procedures -
    button pressing
    procedures below.
    procedures below.
    IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
    Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
    Canon BubbleJet i9950 InkJet Photo Printer Logo
    114 people viewed this question
    old marine
    old marine
