Question about Philips Computers & Internet
Philips 190cw monitor keeps flickering & at times it takes a few seconds before disply is restored
No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 16, 2014 | Acer AL Computers & Internet
190cw brightness box wont leave the creen unless i hold down a button and keep it help down?!
I had this same problem. Check if your system time is correct; as I had problems with the motherboard battery, my Windows time kept resetting, once I set the correct time it worked OK.
Nov 05, 2011 | Philips 190CW8FB LCD Monitor
My Philips monitor 190CW doesn't works in Win7 64-bits. In Win7 32-bits workss well
that's odd?
what operating system do you use?
do you check already the video configuration for your monitor?
Jul 25, 2011 | Philips 190CW
I have horizontal lines on my monitor which is only a year old. I use a AGP graphics card which was also new last year and update my drivers, last update in Feb this year for the graphics card. I have...
try to take out the graphics card and restart your pc on the onboard vga poart of *********** board.
If you are still getting any issue with your monitor you will have to take you monitor to the service station an if it fixes the issue you will have to replace your card ( ie you are having problem with your card not your monitor.)
Apr 02, 2011 | Philips 190CW
Philips 190cw writes on the screen that the keys are blocked
press the ok button and keep pressed upto 15second untill the unlocked messege will appear
Mar 28, 2010 | Philips 150C4FS 15" LCD Monitor
Monitor flicks on but does not stay on
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | Philips 190S5CB (Black) 19 in. Flat Panel...
Philips 190B - flickering screen
Its looks that Inverter board not work well for CCFL cus a CCFL inverter is a device (an inverter) for providing drive power to a Cold Cathode Fluorescent Lamp CCFL
Jun 17, 2009 | Philips 190B6CB/27 19" LCD
Hi, my monitor started to flicker 3times/second persistantly.
its the monitor its the main board may stuff up tomorrow may stuff up next week or in a years time hard to day as its only flickering take in for a check up
Apr 04, 2009 | LG FLATRON L1970HR LCD Monitor
Philips monitor
Sounds like you have a bad inverter. You will need to open up the monitor to get to the screen to access the inverter board and replace it. If you are handy you can do the job yourself but if not then you will need to take it in to a computer repair shop to have it serviced. Depending on how old this monitor is, the cost of the repair maybe prohibitive.
Mar 12, 2017 | Philips 190CW8FB LCD Monitor
My LCD philips 190cw isn't work after i move it??
make sure the video cable is fully connected
Jul 02, 2008 | Computers & Internet
Computers & Internet Logo
644 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
