Question about Microwave Ovens
High Pointe microwave oven in our RV. Turns on but doesn't heat nothing. The serial # is 0612M00010. Its from 2007. Thanks, Shawna
SOURCE: ihave high-pointe microwave oven serial
I also have a High Pointe Microwave Model EM925BSC SN 0608MO3508 manufactured in Aug 06. Tried to use it for the first time this weekend after buying a new Honda EU2000I to use it. The turntable does not turn automatically or when I try to turn it manually. Cooks OK. Nothing in the owner's manual that came with trailer (Zoom 178) mention how to fix the problem.
Anyone have a Ph# for High Pointe. Their Service center address is High Pointe, 2617 N Great Southwest Parkway, #100 , Grand Prarie, TX 75050.
Posted on Oct 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Instruction book required for High-Point microwave/convection
Here's a roundabout way to help you:
You can find a different High-Pointe RV microwave owner's manual here.
That manual should have contact info to help you get in touch with High-Pointe to get a new one, or it may be close enough to your model to work for you.
Posted on Nov 25, 2008
rockitman187
  • 2559 Answers
SOURCE: I need to order a
Here is a link for the mag tube They do not list any for the high pointe brand anywhere, but all you need to do is get the size and wattage from yours and match it to the right one on the site.
Posted on Aug 18, 2010
tbreeze47
  • 3083 Answers
SOURCE: I have a High Pointe
Joe, I'm not sure that's the right model number, since I didn't get any hits on google. Make sure we have the correct number, so that we can help you. Will check back...
Posted on Sep 21, 2010
rickead1
  • 1998 Answers
SOURCE: I have a high pointe
depending on how much you spent on the unit would determine what you should do if you have the model number we would be able to look up your part and give you an estimate on how much to repair as well as some instruction on how to replace the piece that turns the turntable if you were to choose although if you bought the unit at walmart or some place like that it might be easier to just by another one depending on the price of the part it is still getting warm and working just not spining I had one of those while in hawaii stinks to make popcorn with if you have any further questions please message me back and please remember when our chat is through to rank how this opinion has helped it allows me to help others in similar situations Thanks again Rick
Posted on Apr 20, 2011
Testimonial: "Super fast reply! And I am goning to see if I can get further info. Being as it is in my RV, not sure about replacing it."
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
High Pointe Microwave Em925rsl Will Not Heat Food Products and also produces a strong electrical odor
This is a classic sign of the magnetron failing, the most expensive part in the microwave oven.
Jun 29, 2012 | Microwave Ovens
Who makes High Pointe microwaves
Only phone number I could find for High Pointe is 574-848-1118 They are a company called Collins and Co. I have only left a message with someone in the microwave dept. and have yet to hear from them.
Nov 07, 2009 | Haier Microwave Ovens
Turntable continues to run
This seems to be a pretty mysterious situation, and you're not alone in being concerned about an inability to find good contact information.
I would strongly suggest that you contact your RV dealer.
If the parts or service department cannot or will not give you good contact information on High Pointe, i would suggest insisting on speaking to the dealership's manager.
Please let us know what you find out so others can benefit.
Dec 23, 2008 | Microwave Ovens
Nov 24, 2008 | Microwave Ovens
Ihave high-pointe microwave oven serial #0604m00024 manufactured/ april2006 and listed 54nj has benlocked and idont know how to worked please hellpme
Jun 26, 2008 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
