Question about Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A
MY PTO CLUTCH IS SHOT BUT CAN I START MY MOWER WITH OUT IT WIRED UP
  • 605 Answers
If by shot you mean it won't engage, yes you can start the mower. If you mean the anti rotation lugs are broken or the bearing has collapsed then no I wouldn't. Hope this helps, regards Phil.
Posted on May 22, 2011
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
How do I check the PTO switch on my RTZ22 mower?
Hopefully you put back the stabilizer for the clutch assy. If not then it spun the first time you you crank the mower engine and destroy it wiring connections.
If this didn't with the mower not run but the ignition in the on position disconnect the connector at PTO clutch. Now switch on the PTO switch and using a voltmeter (DVM) check for the battery voltage across the two wire at the connector. If voltage is there then the PTO clutch is bad. But if the voltage isn't present then either you have bad PTO or ignition switch or have wiring problem.
Mar 31, 2015 | Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
I have a husqvarna riding mower.. when i engage pto it kills the mower.. i direct wired the pto to the battery and it kicks on and off while mowing, mower runs fine when the pto is off please help
If you wired the pto directly to the battery and still kicks off and on, you have a bad pto clutch. They can be expensive but they are fairly easy to replace. Hope this helped.
Sep 07, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Pto will not start
if its an electrically operated clutch check the fuse to the switch and clutch coil
Mar 18, 2010 | Garden
When I pull out the pto switch the clutch will run for varying short periods of time and then disconnect. I push the pto back in and it will run for a few seconds then disconnect. I havereplaced the relay...
i'm guessing that this is a riding mower? the problem could be the pto switch itself but more than likely the elctric clutch is going bad or the bearings are shot - if it's the clutch, it's gonna be expensive! sorry
Aug 18, 2009 | Garden
Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A Logo
366 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
