Question about Smeg 24 in. DWI612 Built-in Dishwasher
Smeg DI 612 C Domestic Dishwasher
My dw started its cycle as normal then the beep sounded and the 1st light was flashing on the display on the top of the door program,i referred to the manual it described the problem to be the Aquastop failure i checked the water disposal pipe was clear and turned machine off.When i started machine again it started as normal again after 5/6 minutes the beep appeared again i opened the door and on the display the last light was on constant along with the flashing 2nd light i refered to the manual again this told me it was the safety level. I turned the machine of again as it told me in the manual and started new program but the same problem is still happening. HELP PLEASE!!!
  • weenelly21 Sep 30, 2008
    dishwasher begins cycle,then after 5-6minutes it beeps and water seems to be draining off.have checked exit pipes and filter all is clear.please help?
  • philmit Nov 05, 2008
    Same here.... Opened up the drain pump ...all ok, impeller turns and no sign of damage. Took a plumbers drain probe ( long flexible metal spring thing) and pushed it up the drain pipe until it reached the exit port of the drain pump ( just thought there might be a fat blockage in the drain pipe.... Still no go. Just so dam frustrating taht there are no clues from the program.... just reports that the safety switch is active... but of course I cheked the flood safety switch... even cheked each wire from the switch to the processor board. Why is it so difficult to fault find these machines??????
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Posted on Sep 06, 2009
  • Jason Ford Feb 08, 2012
    Hi Phil did the detergent dispencer fix things?
My smeg Module DF 612 SDX7 dishwasher tripped the circuit last night early into its cycle. We could smell burning coming from the dishwasher. Any ideas and what we can do to fix it?
If you can get it to operate for a few seconds, that will at least tell whether the motor is still good and turns freely. Otherwise it sounds like board may have failed.
Jun 21, 2015 | Smeg Dishwashers
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
Shortly after cycle starts, a whirring sound starts, is this a problem with the motor?
with LG dishwashers: after starting, 1st, DW pumps out any remaining water, 2nd, DW fill fresh water, 3rd, main wash motor starts, which is normally a whirring sound. (If you here grinding or rattling, then you have a problem.)
Feb 28, 2011 | LG LD-1420T1 Dishwasher
My smeg dishwasher seems to be permanently in wash mode. The light on the menu of settings no longer flashes, but permanently is on, and when I run a load it never stops. I hear the two beeps as if the...
You have a timer relay issue ,probable need a new board for it ,a cheap fix would be to time it and see how long it take to run full cycle and put a regulaer outlet timer on it or a alarm off your stove or what ever,save a couple of bucks
Feb 16, 2011 | Smeg STX2 Dishwashers
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Smeg DI 612CA
Take a look at this link
Would seem to be the anti flooding device on the inlet hose
Nov 19, 2007 | Smeg 24 in. STX2 Built-in Dishwasher
Smeg 24 in. DWI612 Built-in Dishwasher Logo
1,808 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
