Question about Sony KP-65XBR10W 65" Rear Projection Television
Lack of sharness and focus - Sony KP-65XBR10W 65" Rear Projection Television
No pawer
Posted on May 23, 2011
My NikonD3100 is no longer focusing, my battery is charged and I am at a loss
Make sure you're using a lens that worked before on this camera.. many consumer bodies lack the built in focus motor, so you must purchase lenses that have the motor built into the lens. If it lacks a motor - no auto focus will be possible.
Remove and re-seat the lens.
Make sure that any Aperture ring on the lens barrel is set to the smallest (largest number f22) possible.
Make sure any and all Auto / Manual Focus switches are set to A or Auto.
Try taking a picture in broad daylight - or other well lit area - if the subject is very dark, the auto focus will struggle or "hunt".
Let me know if these suggestions solve your problem - good luck!
Oct 19, 2014 | Nikon D3100 Digital Camera
Diagnostic code p2195 and p1131 for ford focus 2007?
P1131-- Lack of HO2S-11 Switch ,Sensor Indicates lean
P2195-Lack of HO2S-11 Switch,Sensor Indicates Lean
If you have one or two front upstream sensors & have 100,000 miles
on them, replace them as preventative maintenance
The codes are for an Oxygen Sensor closest to the engine,
on the side #1 Cylinder is on
Sensor Codes could be caused buy a leaking injector,
low fuel pressure,running out of fuel,EGR problem,Exhaust
leaks before sensor or converter,any vacuum leak,& other issues
Remove the spark plugs to see if they are fouled from fuel
You can not fix an injector with any fuel tank additive
They have to be removed & mailed away to be cleaned
if they stick open,you could install one if it leaks & is the
only issue.
Oct 01, 2012 | 2007 Ford Focus 1.8
Lack of focus at 20" on zoom
Zoomed fully in, the minimum focus is about 20 inches. If you want to focus closer, you must zoom out. See page 72 of this manual.
Nov 23, 2010 | Samsung S850 Digital Camera
Telescope will not focus. It seems like the focus adjuster won't go in far enough.
Some reflectors like yours cannot be used with certain eyepieces because of a lack of in-focus adjustment.
Sep 22, 2010 | Tasco 49114500 Spacestation(r) 114mm...
Can you give me a name of a baby girl that combines our name sharyl & john paolo please
Sharyl-John
Shary-ohn
Shar-on
Saron
Shir-on
Shir-in
John-Sharyl
John-Sharly
Jaryl
Jarly
Hnaryl
Haryl
Harold
Harley
Horley
Jorly
Jayl
Joyl
Joy
Jun 12, 2010 | ArcMedia ABC of Baby Names
Ford focus 2002 1.6 zetec se it was lacking power when accelerating with juddering and jerking i had a look on the site and was possible for clutch slipping ive since put new cluth on but still lacks power...
SOUND LIKE WEAK PRESSURE PLATE SPRINGS OR CONTAMINATED FLYWHEEL AND PRESSURE PLATE SURFACE HAS OIL ON IT..BESURE TO CLEAN FLYWHEEL AND PRESSURE PLATE MACHINE SURFACES WITH BRAKE PARTS CLEANER.
Apr 22, 2010 | 2004 Ford Focus
Ford Focus 2.0tdci 2005 - Engine suddenly lacking power / noises
One of the air intake pipes had come loose. Fastened the jubilee clip back up and it was like having a new car!
Jan 24, 2010 | 2005 Ford Focus
Best picture settings for 19" philips tv
Brightness set at just half or a weasel hair more. The contrast at 75 to 80% Color at half or one weasel hair more, sharpness at 75%. Sharness is usually the background focus. Tint at half. Actually, I would have to say one of the best TV made is any of the 19" models. They have a rep for really lasting a long....also, the most optimum picture of all sizes made. A note here..sometimes the contrast is called picture, and if you have a cool,warm or normal setting...always go with normal.
Nov 10, 2009 | Philips 19PR19 19" TV
Lack of power / increase power
yes but then it will not pass its annual vehicle inspection because you have done unauthorised modifications.
Sep 03, 2009 | 2007 Ford Focus (3 Door) Hatchback
Sony KP-65XBR10W 65" Rear Projection Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
